It is currently Wed Feb 20, 2019 12:07 pm
Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
PostPosted: Tue May 04, 2004 2:36 pm
Western Digital Hard Drive Diagnostic Utilities
http://support.wdc.com/download/index.asp#diagutils
PostPosted: Tue May 04, 2004 2:40 pm
Spyware Blaster 3.1 - prevents spyware from being installed onto your computer
http://www.javacoolsoftware.com/spywareblaster.html
PostPosted: Tue May 04, 2004 4:52 pm
Free and very highly rated firewall:
http://www.zonelabs.com/store/content/c ... wnload.jsp
If it ain't broke, don't let me touch it!!
P4 Northwood 3.2 (oc'd 3.42)
MSI pt880 Neo mobo
512k (2x256) Geil Ultra Plat. DDR433
160gb WD hdd
Geforce 6200 256mb
Thermaltake Lanfire VM2000-A case
lots of lights and sparklies!!!
PostPosted: Tue May 04, 2004 6:26 pm
FreeRAM XP Pro is a freeware application designed to defragment and free up your system's RAM (Random Access Memory). As a result, system performance, response time, and stability increase. FreeRAM XP Pro uses a minimal amount of memory, system resources, and CPU time, thus making it fast and efficient. It also uses a very fast memory allocation algorithm, allowing it to work quickly with less intrusion on your productivity.
This also useful if your memory is 256MB or below
http://www.majorgeeks.com/download1670.html
Join the Motherboards.org Folding Team 33258
PostPosted: Tue May 04, 2004 7:55 pm
EasyCleaner is a small program which searches Windows' registry for entries that are pointing nowhere. EasyCleaner also lets you delete all kinds of unnecessary files like temps, backups etc. You can search for duplicate files and you can view some intresting info about your disk space usage! You are also able to manage startup programs, invalid shortcuts and add/remove software list.
http://personal.inet.fi/business/toniarts/ecleane.htm
EBCD is a bootable CD, intended for system recovery in the case of software or hardware faults. It is able to create backup copies of normally working system and restore system to saved state. It contains the best system software ever created, properly compiled and configured for the maximum efficient use.
You may download image builder utility which creates image of bootable CD-ROM (.ISO file), plus basic set of system tools. When the image is ready, write it to CD-R or CD-RW, and then everytime you'll need convenient and powerful system tools they'll be just at hand.
It is easy to customize the disk for your needs. You can include to CD any program you like, or remake the structure of CD completely. All you need is to change a few lines in configuration XML files.
http://users.i.com.ua/~ebcd/website/
PostPosted: Tue May 04, 2004 8:06 pm
Remove this if not deemed necessary, but it is important at the moment....
For users running winXP who end up with the Sasser worm do this:
When the shutdown box appears go to START, then RUN and type in shutdown -a This prevents the worm executing... Then go to here...
http://www.microsoft.com/downloads/deta ... laylang=en
This is the XP prevention pack...
Then here to remove the virus from your system - disable system restore first, then run it in SAFE MODE....
http://securityresponse.symantec.com/av ... .tool.html
I know this can be like shutting the stable door after the horse has bolted, but using the stopped command does prevent the virus from executing and gives you time to patch and remove...
PostPosted: Mon May 10, 2004 10:47 am
PRCview for killing spyware/trojans before running your virus scanner
http://www.xmlsp.com/pview/prcview.htm
PostPosted: Mon May 10, 2004 8:00 pm
BIOS Beep Code listing for all major BIOSes.
http://www.computerhope.com/beep.htm
RIAA vs The People
PostPosted: Thu May 13, 2004 12:41 am
I always run Knoppix on a fresh build once completed.
http://www.linuxiso.org/
I find it is the most hassle-free way of ensuring ALL components are working together. It is also very useful for when an HDD dies on you and you need to try to rescue files from it.
Knoppix and the aforementioned memtest are my most used tools when building systems.
Top marks to the MadOnion gear as well :D
Asus A7N8X-E Deluxe
AMD XP2800+ Barton
2x256 Corsair XMS @ 2,2,2,5
WD 1600 SATA
Hercules Rad 9800 Pro
SB Audigy 2 Platinum internal
Waterchill on CPU & NB
Tagan TG-480 U01
Lian-Li V2000
Creative DTT 3500 Digital rewired with Van Damme cable
PostPosted: Thu May 13, 2004 8:12 am
Check this one:
http://www.snapfiles.com/get/kazaagone.html
Removes Kazaa spyware....some say Kazaa has no spyware but if you are like me I take no chances :!:
Benjamin Franklin (1706-1790)
