It is currently Mon Mar 25, 2019 12:15 pm
Post new topic Reply to topic  [ 228 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 23  Next
PostPosted: Sat Dec 18, 2004 11:33 am
Plug the front USB case plugs into the firewire plugs on the motherboard is a no-no. Firewire has 12 volts running through it, USB has only 5 volts running through it!
PostPosted: Thu Jan 13, 2005 9:40 pm
Not inserting the AGP card all the way into the slot. It might seem like its in, but be sure and give it a firm push. dont be afraid.
CPU=AMD Athlon X2 3800+
RAM=Corsair XMS DDR400 1GB 2-3-3-6 Timings
MOBO=ASUS A8N-E
VID=EVGA GeForce 7950GT
HDD=74GB WD Raptor
PostPosted: Thu Jan 13, 2005 9:55 pm
Never put the computer case back together until you are positive it runs properly.
I didn't read through all the pages of this thread so hopefully my tip wasn't already posted.
PostPosted: Thu Jan 13, 2005 11:18 pm
Tip? this is about mistakes YOU have made.
I spilled my guts pages ago, to err is human
PostPosted: Fri Jan 14, 2005 12:58 am
Yes...I have done that before but I'm quite sure others have too.
PostPosted: Fri Jan 14, 2005 4:51 am
Also don't know if this has been posted before but my stupid mistake was terminal.
When attaching the heatsink to an AMD Athlon CPU (it's a tricky little sprung steel strap that clips either side of the socket and requires quite a lot of downward force to get in place) my screwdriver slipped off the clip and scratched the motherboard. That was the end of that.
"It's the best that there is"
PostPosted: Fri Jan 14, 2005 6:42 am
Cable routing is a good practice to allow for better airflow and it makes the inside of the case look neater, but don't do it until you make sure everything works . :D
PostPosted: Mon Jan 17, 2005 2:10 pm
Well this one I felt so dumb for, I was up at 3 AM trying to do something with my parents PC, well I was trying to do something with the CD burner and for some reason I needed to plug it in, well the PC was still on and I thought well it should be fine, plugged the power cord in and click, the PC went off, didn't come back on for 3 days, I was so scared because it was the parents PC which they bought from radioshack for like 1300$ (compaq eh what a joke, and since my PC is broke as of now I'm actually using the same exact PC I'm talking about in this haha.) But ya they weren't too mad since it worked again.
PostPosted: Sat Apr 23, 2005 5:13 am
Online
Make sure your coffee is way, way out of the way when doing work on live systems 8O
PostPosted: Sat Apr 23, 2005 10:05 am
coffee in the keyboard fault. or rodent drowning fault ?
Users browsing this forum: BLEXBot [Bot] and 2 guests
