New comp build problem
- Green Belt
hi there
i am building a new system but i have a problem it seems theres nothing on the screen when i turn it on the motherboard is a K7s5A and the cpu a AMD2100+
everything starts up such as the lights and stuff but as i said theres nothing on the screen its just blank
i'm sure the video card is seated correctly and the keyboard and mouse are too
if you would me to take a picture of inside the new case i can do and post somehow
please help
please help
- Black Belt 4th Degree
- Contact:
Have you moved the bios jumper from clear to normal.
It's usually near the battery, but look in the manual to be sure.
Also, this sounds obvious but I always do it. Turn on the switch at the back of the PSU
[img]http://i3.photobucket.com/albums/y83/RobPope/sigmove.gif[/img]
[b]Jocuri cu impuscaturi[/b] si alte genuri, pentru toate varstele doar pe [url=http://smarturl.it/jocuri]acest link[/url] - distractie si amuzament garantat!
- Green Belt
- Contact:
Is the system bleeping???
Is your IDE cable in the right way round cos this sometimes causes this effect
- Green Belt
- Contact:
Wait another couple of hours untill it gets busy on here cos I'm out of idea's. Some1 else might have an idea and return the board if not.
Sorry, good luck
Sorry, good luck
- Green Belt
- Black Belt 1st Degree
- Contact:
Check again and make sure that the IDE cables are plugged in the right way. Is the HDD set for master on IDE1 and at the end of the cable? Is the 20 pin and the Aux power connector plugged in. Unplug the floppy and try to boot, then the CD rom. Remove any PCI cards. Try booting with one stick of ram in defferent slots, then try the other. Does the video card have its own power connection if so is it plugged in.
ABIT Fatal1ty FP-IN9
C2D 6400
GateWatch-Aerocool
XMS PC800 2gb
2 X 250gb Seagate /Raid0
1900XT
Audigy X-Fi
C2D 6400
GateWatch-Aerocool
XMS PC800 2gb
1900XT
Audigy X-Fi
- Green Belt
