Dumb mistake, Socket 3 486DX2
- Pilgrim
- evasive
- Mobo-fu Master
- Contact:
This it? We might have found back an unknown Freetech board if you can indeed find that ASY number
http://th99.dataspacesys.com/m/E-H/31778.htm
- Pilgrim
- Pilgrim
- evasive
- Mobo-fu Master
- Contact:
We'll name it 486F33 from now on then as that is the standard for Freetech/Flexus.
It's possible the setting are for a newer or older revision of the board. If the silkscreen is present at least it means we're dealing with the same board, albeit another revision.
- evasive
- Mobo-fu Master
- Contact:
Kelly, can you make a backup of your bios with awdflash from a clean DOS bootdisk and send it to [email protected]?
Use this one:
http://www.elhvb.com/mboards/luckytech/awd763.exe
like this:
awd763 /Pn /Sy 486F33.bin
Use this one:
like this:
- Pilgrim
