Do i need update bios on a320 board to use r5 3600?
Post Reply
timotynova
Post by timotynova »
I will upgrade my CPU to ryzen 5 2600, but some peoples say better i upgrade to ryzen 5 3600, my bios version is : AMD AGESA combo-AM4 1.0.0.3, i don't really know about stuff like bios update, did ryzen 5 3600 will work? Or do i need update the bios first?
pc spec:
CPU :Ryzen 3 2200g
GPU : RX 580 8gb
Motherboard : MSI A320M PRO-M2 V2
Ram : 2x4gb 2666mhz
Psu : deepcool 500w 80+
Ssd : samsung evo 860 250gb
Contact:
Re: Do i need update bios on a320 board to use r5 3600?
Post by evasive »
https://www.msi.com/Motherboard/support ... upport-cpu
for Ryzen 5 2600 release 30 of the bios is enough, for Ryzen 5 3600 you need to update to release 34 of the bios. If you update the bios make sure you run the utility as Administrator or it may fail.
Post Reply
