It is currently Tue Feb 18, 2020 1:09 am
Post new topic Reply to topic  [ 13 posts ]  Go to page Previous  1, 2
PostPosted: Sat Oct 12, 2019 2:54 am
It should work out of the 'box' as it is an Atheros chipset and they are generally supported (Broadcom is a different matter). If you can use the latest distro, it will have updated firmware. The only let down on old laptops is the screen resolution (I have some limited to 1024 x 768, works, but looks chunky!).
PostPosted: Sat Oct 12, 2019 8:19 am
I see some issues reported but most of them can be solved with resetting bios to defaults, so if it's initially not working properly, there is the first workaround.
PostPosted: Sun Oct 13, 2019 9:15 pm
It took a couple tries to get the laptop to boot, so I could boot from the Linux DVD. But I got the disc to boot and install. :) Once it installed I checked the internet, and it worked fine. The only minor issue is adjusting the screen resolution to
fit the laptop. When I need to display a video from my laptop on my HDTV, I need to select mirror laptop. With Vista, it did that automatically. :roll: Not a big problem, as long as the laptop boots without issues. :)
Peppermint 10 is nice clean, and simple install. It is fine for what I want on this laptop.
Thx, for the help getting this sorted out.
Users browsing this forum: Bing [Bot] and 3 guests
