It is currently Wed Sep 23, 2020 6:06 pm
PostPosted: Sun Mar 17, 2019 8:53 am
Wellsir ... back to the problem that started this whole new build adventure. :roll: Here is what I did ... I was instructed to install the driver before installing the card. I did. When windows 7 started it installed the driver, but when I go into the device manager I am getting a yellow(!) under the USB controllers section. It is listed as Renesas Electronics USB 3.0 Host Controller. The device status is reporting ... "The device cannot start. (Code 10).
I have tried several different things. Reinstalling the driver. Putting the card in a different PCIe slot. Resetting the CMOS. The only thing I saw in the BIOS about the PCIe was under the Settings\Advance\PCI Subsystem Settings ... PCIe Slot1 Lanes Config. (x16) there is a second option of x4+x4+x4+x4 ... not sure what that means ... it is set for x16. There is something about a PCIe Lane Config. ... MSI M.2 xander/ MSI M.2 xpander-z/ other M.2 PCIe storage card change this item to x4+x4+x4+x4 when using MSI M.2 xpander-z.
Anyone have any idea how I can get this card to work? :-|
Main Rig_Intel i7 [email protected]
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
WD100000 SATA 7200RPM
Seagate 1TB SATA 7200RPM
Corsair CX750M
Rig2_AMD Ryzen 7 1700
MSI Gaming B350
16Gb DDR4 2133
ZOTAC GeForce GTX 550TI
Inland 600 P/S
Win7 64/Linux Mint 19.3
PostPosted: Sun Mar 17, 2019 11:47 am
Make sure the power connector is in and working...
Common issue with windows 7 and USB 3.0.
Check this out...
PostPosted: Sun Mar 17, 2019 1:33 pm
It claims not to need a power supply. It didn't come with a power connector. Those updates the post did to get his card working was for intel boards ... mine is a MSI ... :(
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
PostPosted: Sun Mar 17, 2019 1:57 pm
I'm seeing a lot of reviews on this card where people are having trouble getting it to work on a AMD rig ....
https://www.amazon.com/product-reviews/B011LZY20G/ref=cm_cr_arp_d_viewopt_fmt?ie=UTF8&filterByStar=one_star&showViewpoints=0&sortBy=recent&pageNumber=1&formatType=current_format Can anyone recommend a card that will work on my rig?
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
PostPosted: Mon Mar 18, 2019 12:03 am
USB 3.0 cards usually require to have the extra power if in a PCI-e 1x slot. If it has the input on the card, try it and see. If still no dice, replace the card and use a card with an NEC controller chip (I have had similar issues with ASmedia USB controllers).
PostPosted: Mon Mar 18, 2019 2:00 pm
I'm going to try another one of these hubs https://www.amazon.com/gp/product/B005NGQWL2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1since the first one was bad maybe this one will work. If not I will try another card.
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
PostPosted: Tue Mar 19, 2019 9:00 am
I just pull this out of the box today and it will not work. It caused my system to crash twice ....
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 1000007e
BCP1: FFFFFFFFC0000005
BCP2: FFFFF8800E81FE2D
BCP3: FFFFF88002578808
BCP4: FFFFF88002578070
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\031919-20498-01.dmp
C:\Users\Spirittoo\AppData\Local\Temp\WER-44413-0.sysdata.xml
I see the port lights come on when the BIOS flashes during boot up but when windows opens ... nothing.
It is a Anker 10 port hub
https://www.amazon.com/gp/product/B005NGQWL2/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Any idea what the problem is? I know the ports on the mobo work because I plugged other devices in them.
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
PostPosted: Tue Mar 19, 2019 10:07 am
Talked with tech support about the hub. Apparently it is not compatible with my system. I have no idea why. I'm returning it and trying another PCIe card.
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
PostPosted: Wed Mar 20, 2019 7:54 am
Okay here is the plan ... I have this card coming tomorrow ...
https://www.amazon.com/gp/product/B00FPIMICA/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
If it doesn't work I have this hub coming some time next week.
https://www.ebay.com/itm/7-Port-USB-3-0-Hub-5Gbps-High-Speed-On-Off-Switches-AC-Adapter-for-PC-Laptop-Mac/264096102905?ssPageName=STRK%3AMEBIDX%3AIT&var=563652023339&_trksid=p2060353.m1438.l2649
I know this hub will work because I am using the 4 port version of it now on the Ryzen rig. So we shall see if the card works tomorrow.
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
PostPosted: Wed Mar 20, 2019 11:57 am
That card DOES have a power connector that you DO need to connect.
