It is currently Tue Feb 18, 2020 2:06 am
 Post subject: Bad USB Port On Mobo
PostPosted: Thu Feb 21, 2019 11:18 am
This is for my AMD Gigabyte computer. One of the 3.0 usb port has gone bad. I had a hub with power hook up to it, and I was having problems with devices that were plugged in to it. I tried to plug the hub into a good port, but not all the devices plug in are showing up. I needed more hubs so I hook another 4 hub with power to the first hub. They are not the greatest hubs either. Also I am hearing the sound when the usb device is plugged and unplugged. Is there anything that can be done to correct this problem?
Main Rig_Intel i7 4770k@3.50
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
WD100000 SATA 7200RPM
Seagate 1TB SATA 7200RPM
Corsair CX750M
Win7 Ultimate x64
Rig2_AMD Ryzen 7 1700
MSI Gaming B350
16Gb DDR4 2133
ZOTAC GeForce GTX 550TI
Seagate BarraCuda Pro 4TB SATA 7200RPM
Inland 600 P/S
Win7 64
 Post subject: Re: Bad USB Port On Mobo
PostPosted: Thu Feb 21, 2019 12:45 pm
Sounds like you might want to invest in a higher-quality hub. :wink:
-R
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Thu Feb 21, 2019 4:02 pm
I ordered one of these ...
https://www.amazon.com/Anker-9-Port-Smart-Charging-Adapter/dp/B005NGQWL2/ref=sr_1_4?ie=UTF8&qid=1550793489&sr=8-4&keywords=Anker+10-Port+USB+3.0+Hub
Do you think that will do the job? :-|
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
Win7 Ultimate x64
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
Win7 64
PostPosted: Fri Feb 22, 2019 10:01 am
Appears to - should provide enough power to all ports w/ the power adapter it has, plus gives you one high-powered plug.
-R
