It is currently Tue Jul 14, 2020 8:49 am
 Post subject: Need Advise on RAM
PostPosted: Tue Jan 01, 2019 9:28 am
My desktop computer has an Intel DQ35J0 MB that has 4 slots for memory. I recently did a fresh install of Win10 and currently have all memory 4 slots occupied with Kingston 2GB 240-pin SDRAM - DDR2@ 397mhz (I have a total of 8gm RAM)
I have to apologize, I am no where near an expert on knowing just what thresholds exist for this motherboard. So my questions that I am seeking advise on are:
1 - Is the memory now maxed out? Is there room to expand to more and if so will that make the machine run better with Win10?
2 - If so, I am looking for a recommendation of what to purchase and from where.
Any advise is greatly appreciated.
Antec 900 - 650W ATX
Intel DQ35JOE
MS Windows 10-64bit
 Post subject: Re: Need Advise on RAM
PostPosted: Tue Jan 01, 2019 10:25 am
RAM will be maxed out. Getting hold of 4GB individual sticks of DDR2 is hard and usually if not all is server grade (registered and ECC) so won't work. If it all works with what you have and runs fine, don't waste money on a RAM upgrade. Where to put the money in upgrading these days is in a decent SSD - For Windows, always buy a decent one, ie Kingston Crucial, Samsung (EVO) and you won't go wrong. My advice, 8GB of RAM is enough for most applications, speed windows up by running it off an SSD, 240Gb minimum and store all your files on other drives.
PostPosted: Wed Jan 02, 2019 6:23 am
Thanks for the reply Mr T
One more question please. I need to be careful of what SSD i order, preferably from Amazon, because of my hardware configuration. Might I ask you to find a recommendation or two based on what I have provided below?
Desktop Win10 PC
DDR2 RAM
Intel DQ35JOE
MS Windows 10-64bit
PostPosted: Wed Jan 02, 2019 6:52 am
Also I forgot to mention...............
I/O Specifications
USB 2.0 Configuration (External + Internal)
6+6
Total # of SATA Ports
6
# of eSATA Ports
1
Not sure if this board allows SATA III connectors or not
Intel DQ35JOE
MS Windows 10-64bit
PostPosted: Wed Jan 02, 2019 11:12 am
SATA 3 is backwards compatible with SATA 2 - so no worries there. you'll just transmit at SATA 2 speeds.
Crucial provides a "guaranteed" compatibility list for your MB:
https://www.crucial.com/usa/en/compatib ... SSDFilters
You can get a 250gb MX500 for $50(comes with a 9.5mm adapter as well).
I've had a few Crucial SSDs have nothing but praise for them so far. You're more than welcome to shop around to other manufacturers obviously though - you'll find lots of options out there.
-R
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Wed Jan 02, 2019 11:26 am
I concur, Crucial, but I also use Kingston and Samsung, but the Samsung EVO's are a bit more expensive as they have faster read/write speeds. If you do get Crucial, 240Gb minimum for windows and get the MX500 series - a bit quicker...
Users browsing this forum: Majestic-12 [Bot] and 2 guests
