It is currently Thu Feb 20, 2020 8:20 pm
 Post subject: RAM Added to MB
PostPosted: Mon Oct 15, 2018 10:37 am
I have a DQ35JO motherboard. i just updated the RAM from 2 sticks (4gb total) to 4 sticks (4gb total). All 4 slots are now occupied
I ran Speccy to see if the system recognizes the additional memory and it is showing
Physical Memory
Memory Usage 33 %
Total Physical 3.24 GB
Available Physical 2.15 GB
Total Virtual 5.08 GB
Available Virtual 4.16 GB
Does this seem correct?
I was expecting to see total physical = 8gb
Should I have changed a dip switch or something?
Antec 900 - 650W ATX
Intel DQ35JOE
MS Windows 10-64bit
 Post subject: Re: RAM Added to MB
PostPosted: Mon Oct 15, 2018 11:03 am
https://social.technet.microsoft.com/Fo ... proinstall
Take a look at the options detailed there and see if something sticks out to you.
Thanks,
-R
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Mon Oct 15, 2018 1:27 pm
That did not help........
BTW........I am on XP operating system
I went from 4gb to 8gb
Intel DQ35JOE
MS Windows 10-64bit
PostPosted: Tue Oct 16, 2018 8:11 am
XP is limited due to it being only 32bit - you'll need a 64bit OS in order to utilize more than 3.25gb of memory. :(
There's workarounds - but, it involves using other software to allow it. I've never done it, and don't know anyone who has so your experience may or may not be exactly good. Some options are things like RamDisk to use the extra memory for storage/pagefile usage. Other methods are not legal due to breaking the licensing/editing the kernel.
-R
PostPosted: Sun Feb 10, 2019 5:11 am
When upgrading to windows 7 (or even windows 10 as it will run on that board) make sure you get the 64bit variety.
