It is currently Tue Feb 25, 2020 1:18 am
PostPosted: Sat Sep 22, 2018 11:07 am
I have a second hand HP Photosmart C4200 Series Printer/Scanner/Copier that I got a couple years ago.
So far I've used its Printer & Copier features with decent success. Just the usual printer outta ink B.S. Other than that no problems.
Now I'm working on a project that needs items scanned. But I can't get this thing to work properly.
I tried reconnecting it, rebooting my WIN10 PC. It sounds like it is scanning but I don't see the images?
The HP Photosmart C4200 added the directories, but nothing is showing in them.
C:\Users\Username\Documents\My Scans
START\ThisPC\Documents\My Scans
How do I get this to scan properly? Is there any Freeware software I can use that would work?
PostPosted: Sun Sep 23, 2018 8:13 am
Can the unit do a copy feature? If so, then the unit is working properly, but likely a driver issue.
Found a link for HP support that recommends removing the device and drivers from your Win 10 setup, then installing new drivers and the unit. Hope it works.
https://h30434.www3.hp.com/t5/Printer-S ... -p/5199085
Also, the Adobe® PDF program can work with most printer/scanner models, and can convert most pages to a standard PDF file.
On the site page, there is an option to have the McAfee® security features. If you already have a similar AV/scan program, opt out of that addition. Two similar active programs can affect overall system performance.
https://get.adobe.com/reader/
PostPosted: Mon Sep 24, 2018 9:45 am
Thanks,
The HP site has way too many "fixes". lol
But I did manage to stumble on a solution. To get it to scan I need to do the following:
Click: Start / Control Panel / Devices & Printers / RClick on HP Photosmart C4200 Series / Select scan
It opens up a new window where I need to import the scanned pages, etc. I just move them to were I want them. I
PostPosted: Tue Sep 25, 2018 7:39 am
Good to hear all is working again. And maybe the same tip works for other users.
PostPosted: Tue Sep 25, 2018 9:39 am
I hope so. :)
For some reason the scan controls on the HP Photosmart C4200 don't work. But the the copy works fine. :?
Well at least all three features work. :)
PostPosted: Wed Sep 26, 2018 6:13 am
If you keep the printer on mains power all the time, possibly a 'blip' in the power mains have confused the controller. Unplug and wait about 15 seconds, then try again. Should be OK. Same applies to any electronic device with a memory controller.. any TV, microwave, coffee maker, security monitor, routers. Preferred that many devices be unplugged until needed. The power supplies in them are always on, few exceptions. Might save a few dollars per month on electric bills.
