It is currently Sun Jul 12, 2020 11:48 am
Post new topic Reply to topic  [ 13 posts ]  Go to page Previous  1, 2
PostPosted: Sat Mar 10, 2018 2:43 am
Did it suffer the same symptoms before you upgraded to windows 10?
PostPosted: Sat Mar 10, 2018 8:27 am
The power and reset buttons are only momentary-contact, normally open. No polarity issues with them. The power/other LEDs are polarity sensitive. Should be a small diagram by the FP header as to pin functions, or will be in the user manual.
Some motherboard designs may have a 'message' or 'msg' LED connection, which would blink the yellow LED for a problem or status. Just an option.
Windows 10 has changed a lot, and is not compatible with a lot of older software or hardware.
Check https://www.microsoft.com/en-us/windows ... ifications to ascertain. A BIOS update may clear any issues, but maybe not.
Mr T has a good question.. was this problem present before the Win 10 upgrade?
Is that motherboard certified for 64-bit operation, or only 32-bit?
Possibly the Microsoft® site will have upgraded drivers for certain hardware on that motherboard that are more compatible.
PostPosted: Mon Mar 12, 2018 7:08 am
Open the case and make sure the top of all capacitors is perfectly flat, not bulging in the slightest.
https://www.badcaps.net/index.php
If they are bulging the board needs repairs, is this system still under warranty?
