I am pulling out my hair with computer crashes
Re: I am pulling out my hair with computer crashes
Postby evasive » Wed Feb 21, 2018 3:19 am
For once I do not suspect the power supply:
http://www.jonnyguru.com/modules.php?na ... y&reid=440
However, you stay may have trouble on your mains circuit that can causes troubles. If at all possible, can you barter/borrow/rent an UPS to cross that one out?
What are those GSkill memory sticks exactly? Are they listed in the compatibility list for this board? Asus has always been finicky with memory over the years, I don't expect that to change much.
Is it possible to use the onboard LAN instead of the USB wifi to exclude any driver problems with that?
Is it possible to disconnect the DVD drive?
What bios version are you using?
Did you check if there are any newer drivers available for that video card? Did you have any other video cards in there before and did you _completely_ uninstall the drivers for that one?
Previous
Return to Tech Support
