It is currently Sat Jun 06, 2020 7:32 pm
 Post subject: Drag & Drop Feature
PostPosted: Sun Dec 24, 2017 8:48 am
Having used Windows 10 Pro now for a while I can't say anything good about it, zero.
Always used Drag & Drop in previous Widows operating systems a very useful feature, but it seems that feature is no longer available in Windows 10. I read where you can disable UAC in the registry but it seems doing that creates other issues so I won't go there. It seems that the only other way to move a file from one folder to another is via cut and paste which is a pain in the butt if you have a lot of files to move.
Is there any other way to drag and drop files or folder in W10 ?
Thanks & Merry Christmas
KEEP AMERICA GREAT
 Post subject: Re: Drag & Drop Feature
PostPosted: Sun Dec 24, 2017 9:49 am
Merry Christmas to you also.
A lot has changed in Win 10, some features lost from previous versions. But the default use of the right-click on a file or folder, then drag to another location, should give the choice of 'move' or 'copy'.
May be an easy resolve here.. https://www.tenforums.com/tutorials/380 ... ndows.html
PostPosted: Mon Dec 25, 2017 4:51 am
There is no option to MOVE. Just CUT & COPY
KEEP AMERICA GREAT
PostPosted: Mon Dec 25, 2017 10:56 am
You can COPY and PASTE like all other Windows. I still use Teracopy to copy files as it doesn't stop completely with no warning if there is an issue copying files (such as a duplicate file). I have also selected all files and just moved them over to other drives with no issue.
Merry Christmas.
PostPosted: Wed Dec 27, 2017 10:26 am
huh...I have had no experience like you mentioned while moving around files on my Win10 machine...?
-R
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Fri Feb 23, 2018 2:46 am
It all depends on where you want to drop things and what security is set on the target folder. W10 is a lot more strict by default so maybe all you need to do is adjust the security settings on the target folder and there ya go.
PostPosted: Fri Feb 23, 2018 7:05 am
I still prefer Total Commander from http://www.ghisler.com/ which is superior to the resident 'file manger' in most OS versions. Also a file editor, creator, file/folder mover and packer. Works seamlessly within Windows. Can rescue a lot of older files for use, and view hidden/system files.
Any duplicate files going to a place, TC will warn you and display stats for comparison.. copy over, skip, rename or delete.
