It is currently Fri Jun 05, 2020 9:53 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Oct 07, 2017 5:15 am
Check with Task Manager as to what applications are active even if not in use. Could be one is 'captive' by some other program.
You don't need other programs constantly checking for updates. Once or twice daily is more than sufficient, even for antivirus programs. Only if you have a server setup, would it be proper to update every few hours.
Only one browser should be set as default. Check each browser as to latest version, from the 'tools' tab or the 'about/options' tab. IE may need a manual input for updates.
PostPosted: Sat Oct 07, 2017 10:08 am
I think your CPU may be faulty. Try a few burn in tests and see how they perform (like Prime95) - browsers tend to use a lot of RAM and processing power...
PostPosted: Sat Oct 07, 2017 5:23 pm
There is nothing showing in the task manager other than Comodo, malwarebytes tray application and the browser FF Nothing unusual in the hijack log then? Is there a free program to test the CPU? I have noticed that IE will tell me the page I am on is not responding will ask to close the page then will open back to that page and it will respond again for a while. In FF when it doesn't respond I have to open a new tab ... copy the address from the other page that no longer responds and page it in the new tab, then it will respond again. I have a much more difficult time at youtube. I it will stop responding frequently and I have to follow the procedure of closing and opening tabs several times before it will play the video.
Main Rig_Intel i7 4770k@3.50
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
WD100000 SATA 7200RPM
Seagate 1TB SATA 7200RPM
Corsair CX750M
Rig2_AMD Ryzen 7 1700
MSI Gaming B350
16Gb DDR4 2133
ZOTAC GeForce GTX 550TI
Inland 600 P/S
Win7 64/Linux Mint 19.3
PostPosted: Sun Oct 08, 2017 6:11 am
Looks like a memory leakage issue - bear in mind the RAM controller is on the CPU and not the chip set. If you experienced this issue from day one on another motherboard, motherboard has been changed, windows reinstalled and the same issue crops up, I would say CPU.. Easy way to check is to beg/borrow or buy another CPU to test with (if you buy, get a cheapo Celeron from Ebay and you will be surprised how powerful Celerons are)..
PostPosted: Sun Oct 08, 2017 8:35 am
I'll have to dig out an old program I have that will test the CPU it takes several hours to run ... no way can I afford a new CPU now ... not as fast as the one I have which is needed to run my Flight Sim programs.
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
PostPosted: Sun Oct 08, 2017 10:47 pm
I ran a program call hot cpu tester. Checks out most of the hardware. There were no errors including the CPU.
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
PostPosted: Mon Oct 09, 2017 10:09 am
Download openhradwaremonitor, install it and run it.
Download Prime95. Open it up and don't run it.
Open up a browser, Firefox is good as it is very resource hungry.
See what temps your CPU gets up to while running a Youtube video - should go up to about 50 deg C or there a bouts.
Then start Prime95 running and see what happens to the CPU temps and if the Youtube video crashes or stutters..
Edit:
Also open up Tak Manager and see what resources are being used...
PostPosted: Tue Oct 10, 2017 11:15 am
With the browser off .... the cpu temps range from 57 to 61C ... with FF running it's 66C .... with the stress test from prime the temp shoot to 100C. With the test off I could not get the youtube video to play ... the browser stops responding in FF. I can do it with IE I think. Is there a certain period you are suppose to run prime?
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
PostPosted: Tue Oct 10, 2017 12:30 pm
Did the stress test with IE playing youtube video ... it continued to play. But I still having problems with both browsers not responding often where I have to keep closing and reopening them, or reloading or opening a new tab and closing the tab that won't respond.
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
PostPosted: Wed Oct 11, 2017 6:24 am
Could be a massive load of "tattle" and "tracker" cookies from worthless sites. The security features on browser programs today don't really block those third-party cookies. Sending the bits of your browsing habits to them and getting feedback ads wastes precious data cycles.
