It is currently Thu May 28, 2020 1:12 pm
PostPosted: Wed Sep 06, 2017 10:05 am
Hi people.
I want to add a M2 hard disk to my MoBo but my BIOS won't detected.
I purchase a PCIe 16x adapter for my M2, my BIOS won't show my new drive.
I had update the BIOS but same thing.
I cannot see my new HD.
I try changing some settings in my BIOS to.
Any tip?
Thanks.
PostPosted: Thu Sep 07, 2017 8:26 am
Is the hard drive capacity (cylinders, heads, sectors) within the BIOS limits? If a PATA or IDE drive, are any jumpers set properly? And if using an 80-wire data ribbon, on the proper header?
For a SATA drive, if a class 3, it may not be recognized on a class 2 or class 1 system. Might be a jumper on the drive to revert to an older class.
https://kb.sandisk.com/app/answers/deta ... d-sata-iii
PostPosted: Sun Sep 10, 2017 2:28 am
The BIOS won't see it as it is not technically a hrad drive attached to the SATA ports. Is it seen in the operating system? Do you want to install an operating system to it?
PostPosted: Mon Sep 11, 2017 12:10 pm
on the advanced tab, under pch storage configuration... anything in there?
seems this mobo outa be new enough to be able to see a pcie m2 device in the bios, but maybe not since it's not embedded onto the mobo through native connector.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
