It is currently Fri Sep 18, 2020 4:04 pm
 Post subject: HP Z600 Workstation
PostPosted: Mon Aug 07, 2017 6:10 am
I bought a used HP Z600 Workstation with Win7
In an effort to find out if I can add memory and a better video card, I have the need to find out what power supply I have and existing memory type, what is the best memory I can add to the machine, etc...........is there an application that can tell me all of this? HP was of very little assistance.
Antec 900 - 650W ATX
Intel DQ35JOE
MS Windows 10-64bit
 Post subject: Re: HP Z600 Workstation
PostPosted: Mon Aug 07, 2017 7:40 am
The info is there.. just the right "door" to choose to find it.
https://support.hp.com/bg-en/document/c01719966
https://www.newegg.com/Product/ProductL ... Submit=ENE
PostPosted: Mon Aug 07, 2017 8:36 am
WOW........thanks...............guess I did pretty good getting one for $25 based on the price on the Newegg page
Intel DQ35JOE
MS Windows 10-64bit
PostPosted: Mon Sep 11, 2017 12:31 pm
all the z800's I dealt with were dual processor rigs.
if the z600 has a similar mobo, it gives you all kinds of opportunity to update to many cores, and much ram.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
