It is currently Sun Sep 20, 2020 9:07 pm
 Post subject: Intel Quick Sync Video
PostPosted: Fri Jul 07, 2017 7:42 pm
My CPU supports intel quick sync video. My boardboard diagram shows that the CPU is connected directly to the hdmi port but goes through the chipset to connect to d-sub. My monitor is connected to d-sub and I cannot get intel quick sync to work. Do I need to connect my monitor to the HDMI port to get Intel quick sync video to work?
PostPosted: Mon Jul 10, 2017 7:15 am
HDMI is similar to USB use, with two-way data links. The D-sub (for VGA) is only one way, but does have device ID feedback to the system. The CPU itself cannot produce the desired video data without a rendering interface, found in the North bridge chipset or in another dedicated chipset.
PostPosted: Tue Jul 11, 2017 10:06 am
Your conclusion is that it should work. What will prevent it? Drivers? BIOS setting? Something else?
PostPosted: Wed Jul 12, 2017 7:58 am
A better description of your system would be good, for better diagnosis and suggestions.
Brand, model, CPU speed, memory, other features and age of the system.
What was posted is general practice for almost all systems.
PostPosted: Wed Jul 12, 2017 11:00 am
you may need to make sure the onboard video is enabled in the BIOS. check the mainboard manual(if you can find it) or just poke around in the BIOS until you find something along the lines of Internal Graphics or Primary Display or Muli-Monitor...iGPU...
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
