HP Spectre x360
HP Spectre x360
Postby BenK » Sat Apr 22, 2017 9:34 am
Hi All
As you can see in the attached image, a piece attched to my pc's motherboard is loose and about to fall off. It is barely connected on the left side.
IMG_20170421_090524388 (Medium).jpg (158.73 KiB) Viewed 418 times
InkedIMG_20170421_162247158_HDR_LI (Large).jpg (190 KiB) Viewed 418 times
Does anyone know what this transistor (or whatever it is) does?
So far, I haven't noticed any changes to the running of my pc.
Thanks in advance.
BenK
Re: HP Spectre x360
Postby Mr T » Mon Apr 24, 2017 11:17 am
Does it wobble or move, if not then it is just making a contact and working so leave alone?.. If it is moving and looks like it may come off, heat it with a heatgun until you can move it into its correct position, then leave alone until it is solidly stuck on.
Re: HP Spectre x360
Postby BenK » Tue Apr 25, 2017 3:07 am
Yes it does wobble. It is not making a perfect connection on the right side.
I'm not able to fix it for the next 2 weeks.
Do you think I can still use the pc, or will it cause sparks/short circuit?
BenK
Re: HP Spectre x360
Postby evasive » Tue Apr 25, 2017 12:49 pm
It looks like a small capacitor, if it's not connected properly the machine might be a bit less stable. I'm not expecting sparks however. Having any component risking to become completely loose is giving a risk of a short circuit so have that fixed. Now.
Return to Tech Support
