It is currently Mon Jul 06, 2020 5:02 pm
 Post subject: Keynote downgrade
PostPosted: Tue Dec 13, 2016 11:16 am
I want to downgrade Keynote to version 5.3 on my macbook pro 2015 running Yosemite.
Can I just drag the Iworks folder to the recycle bin and install a stand alone disk of Iworks '09?
thanks
crispr edit
 Post subject: Re: Keynote downgrade
PostPosted: Sun Jan 29, 2017 8:41 am
Not sure. What I do know is that you will need to export or save your files in a format that version 5.3 can handle. otherwise you won't be able to open them. There seems to be almost NO backwards compatibility between what each version creates. I'll see if I can find out if indeed simply deleting the application and installing it from the CD will work.
Users browsing this forum: No registered users and 7 guests
