It is currently Fri Jun 05, 2020 12:12 pm
PostPosted: Fri Oct 14, 2016 8:07 am
win10 and the hp zbook 15 g3 laptops we sell do not provide a recording device "stereo mix". it was the same on win7, but there was a fix for it by editing some registry keys. this same fix doesn't work for win10, unfortunately. the audio chip is from Conexant. tried hacking chdrt.inf file in the hp driver package for audio too. no dice.
anybody out there find a way to enable stereo mix on Conexant chips in win10?
TIA.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
PostPosted: Sat Jan 28, 2017 3:02 pm
What is your registry hack for this? Maybe it needs a bit of massaging to fit into windows 10
PostPosted: Tue Feb 07, 2017 12:49 pm
thanks for replying...
so, you need a certain Conexant driver package from hp, uh, including or before sp75820. I can get the driver version number if you need, but let's just say this fix doesn't work on windows 7 after they released a newer version of the audio driver.
three regfiles...
ControlSet001.reg, which contains...
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\Settings\EPattributes\EpSettings\StereoMixEnable]
"Enable"=hex:01
"MixAssocSeq"=hex:e0,e0
"MuteGainSettings"=hex:00,00
ControlSet002.reg, which contains...
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\Settings\EPattributes\EpSettings\StereoMixEnable]
"Enable"=hex:01
Stereo Mix.reg, which contains...
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96C-E325-11CE-BFC1-08002BE10318}\0000\Settings\EPattributes\EpSettings\StereoMixEnable]
"Enable"=hex:01
I had a better idea what all these did back when I posted this originally. I'm a little fuzzy now, except I know this fix, and others ive tried on multiple driver install versions have not worked on windows 10.
now, we also use windows 10 on a desktop platform that uses realtek audio chips, and we have yet to have this problem with those.
any questions, I'm happy to answer.
my main rig...
asrock 970 extreme3
antec neo he 650r
PostPosted: Tue Feb 07, 2017 1:14 pm
It points at the MultiMedia Class for devices:
https://msdn.microsoft.com/en-us/librar ... 2147217396
It seems you don't need to mess in the registry this time:
https://answers.microsoft.com/en-us/win ... 23d84bc5bc
Provided you already removed the semicolons from the .inf file.
