It is currently Sat Sep 19, 2020 11:58 am
 Post subject: Win7 Network help
PostPosted: Sat Apr 09, 2016 10:36 pm
Been a long time since I've been here. Sure has changed!
Problem, cannot setup home group with 2 Win7 systems. Don't know where to start explanation. The one computer states it cannot setup work group.
Computers just keep changing.
 Post subject: Re: Win7 Network help
PostPosted: Sun Apr 10, 2016 12:17 am
Here is how to create a WORKGROUP. Once that is done and your PC's are set to communicate with each other. Follow this...
PostPosted: Sun Apr 10, 2016 12:54 am
Hey T, It's sure been a long time. Thanks for the help. Wasn't sure if anyone was still around.
I think I've gotten it working but not sure it's correctly. I can now access everything but it sure seems like a round-about way of doing things. I recall XP being much more seamless.
Now all I need to do is figure out how to access the iTunes that are on the other computer. If that's even possible. I can find the files and play list but I can't get it to play.
PostPosted: Sun Apr 10, 2016 6:00 am
Part of the 'Digital Rights Management' process (DRM). Those files need authorization to be accessed (or played) with a bit of software installed by the copyright owner of them. Yes, you buy those files, but they still are the "intellectual property" of the creator. Same as with any computer OS. Sharing or cloning of files without permission is considered as piracy.
PostPosted: Sun Apr 10, 2016 7:31 am
OK, Understand. Looks like I need to get my IPOD fixed as I've bought a lot of new stuff that's not on it.
PostPosted: Sun Apr 10, 2016 11:17 am
Have you tried setting the itunes folder where all the music is stored to be shared? I download my itunes stuff as mp3 and save it to another folder (not on my C drive) so it can be secured if windows screws up and it can be shared to my other pc's (not to other people as I paid for it)... It's nice to see some of the old 'names' return... :D
PostPosted: Sun Apr 10, 2016 4:56 pm
The original was set up with iTunes program on C and all song files on an separate E drive. Everything still works. I then bought a new computer and loaded iTunes on it. Cloned the E drive and it worked but when I tried to put the clone in the new computer it won't read it. Does that make sense?
PostPosted: Wed Apr 27, 2016 12:07 am
Open in explorer, right-click, take ownership of it. Your old account (and the SID) does not exist on the new system.
