hi everyone, i m new here, i m cuban and my english is not good!! so apologize me for language canibalism!!
Yesterday I set up a Foxconn G31MX motherboard with celeron d and a 1GB RAM, work perfectly while in horizontal position, opened windows xp and work well, then send it to shut down to close the chassis and place it in its original position, disconnect all the rear connectors and put right the chassis. when you plug it in and try to turn the pc, this simply could not sign on, try it several times but nothing. opened the chassis to examine whether there were any disconnected cable, but everything was fine, then remove the mobo to test only with PSU and here is where the problem: when I bridge in the ON / OFF mobo connectors are not turned on, the fan does not he made to walk, it is not like other cases you have seen hechan to walk and stand, and what remains is that I doubt that plug into USB ports either mouse or modem blink. please if someone could tell me what happened to the mobo, if it was a power failure or something. Thanks in advance
