It is currently Thu Feb 27, 2020 9:07 pm
PostPosted: Sun Mar 20, 2016 12:16 pm
Greeting!
I am kind of confused, since the AMD Phenom II X4 965 was listed as supported on this Website but msi warned about using 95+ watt processors on this mainboard proof(site is in German but the warnings are in English tho').
On the other hand they did not show this warning on the English site.. proof again
So is it save to use? Or should i better buy a new motherboard?
BTW sorry for my broken English, but I am not a native speaker... but you may have noticed that already.
PostPosted: Sun Mar 20, 2016 3:24 pm
If the motherboard provider warns about using a non-certified CPU, the advice should be heeded.
Could cause damage to the board or CPU.. possibly fatal.
The motherboard provider has a QVL (qualified vendor list) that notes what CPU, memory or other devices are tested and certified for use with the board model.
PostPosted: Sun Mar 20, 2016 11:13 pm
If you look on the english site list, the 965 is not listed as compatible... I would look at another board......
PostPosted: Mon Mar 21, 2016 6:15 am
Thanks for your quick answer.
I am going to look for a new Board :/
Users browsing this forum: No registered users and 9 guests
