Unknown causing cmd.exe to launch with suspicious cmd call
Re: Unknown causing cmd.exe to launch with suspicious cmd c
Postby Karlsweldt » Thu Jan 29, 2015 6:34 am
A lot of links for "Background Intelligent Transfer Service". One advises updating the version for XP.. http://support.microsoft.com/kb/923845 and for Vista, http://support.microsoft.com/kb/940520
About BITS.. https://msdn.microsoft.com/en-us/librar ... 85%29.aspx
Postby joe_devore » Thu Jan 29, 2015 12:08 pm
thx Karl but I was just updating my topic with a bit of new info....
turns out the version of BITS installed is XP 64bit is:
FILE : v6.6.3790.3959
DATE: Sunday, February 18, 2007, 7:00:00 AM
anyway it seems this update was never released as the version
v6.7.3790.4089 is the version listed as the newest for server 2003 64bit which should be the version for XP.. yes there is a download for XP x64...
I wonder why they never pushed it to windows update....!?
anyhow am installing now.. brb
EDIT:
update was smooth not a problem all files related updated, old stuff is byebye.
(PC Specs)
CPU: AMD FX-9590 4.7GHz 8-core
CPU Instructions: MMX(+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
Motherboard: Asus SABERTOOTH 990FX R2.0
GPU: nVidia GTX 750Ti SC 2GB
GFX Drivers: Nvidia v398.36
OS: Windows 7 Ultimate 64-bit SP1
RAM: 32GB Kingston 1866MHz DDR3
joe_devore
Postby Karlsweldt » Thu Jan 29, 2015 5:25 pm
Since it isn't considered a security issue, not in the automatic update category.
Going to the MS update site and checking the "optional" updates should show it plus any other device drivers that are more compatible with the OS versions.
Hope all your troubles are "blown away".
Postby joe_devore » Fri Jan 30, 2015 2:51 am
Karlsweldt wrote:Since it isn't considered a security issue, not in the automatic update category.
Karlsweldt wrote:Going to the MS update site and checking the "optional" updates should show it plus any other device drivers that are more compatible with the OS versions.
nahh MS and windows update both show zero updates available , not one not in any category.... =(
Karlsweldt wrote:Hope all your troubles are "blown away".
thx Karl
(PC Specs)
joe_devore
Previous
Return to Tech Support
Users browsing this forum: AhrefsBot [Bot] and 3 guests
