Unknown causing cmd.exe to launch with suspicious cmd call
Postby joe_devore » Sat Jan 10, 2015 9:24 pm
starting just idk last night the day before....
I found this odd cmd window poping up on load of my desktop..... O_o :?
i tried Google-ing it to no avail..
I checked CCleaner, Spybot, and the run regedit keys and Autoruns (System Internals) could NOT find ANY AutoStart reference ANYWHERE ;>_<; O_o
Code: Select all
C:\WINDOWS\system32\cmd.exe  /K for  /F %i in ('dir /b /a:h-d /w "C:\Documents and Settings\All Users\Application Data\1837308050\*"') do start /b regsvr32.exe /s /n /i:"/64 QV0RLkDNJMohCCDWYSLNtdRXIPOZUAogex4Cn5ppPJig1KKm3 " "C:\Documents and Settings\All Users\Application Data\1837308050\%i"
I had Process Monitor (by System Internals) do a bootlog ^_^ haha
UNKNOWN_cmd_start_.txt__ProcessMonitor-Logfile__short.PML
is a short logged pre-filtered looking for "1837308050"
and an exported xml file...
the pml file is easier to read but you will need Process Monitor to open/read it.
now I could attach an archive with them in it or I could just post the links for the download page at System Internals home website..
http://technet.microsoft.com/en-us/sysinternals/bb896645
note the 64bit version of Process Explorer and Process Monitor are held internally to ones you will download from their home site...
if your system is 64bit it will auto extract the 64bit exe to the temp folder so just grab a copy from there to have your own permanent copy of it.
ps:
its possible I deleted that #'ed folder finding its existence suspicious and the files found there were not associated with any known program I use......
since I cannot upload a text file (<<-- REALLY? GIVe me a break a txt file?! :roll: )
I have attached a rar archive containing a text file with the cmd string as well as the Process Monitor log files.
UNKNOWN_cmd_atempting to run_.rar
Text file with cmd string and Process Monitor Log files.
(111.69 KiB) Downloaded 38 times
joe_devore
Re: Unknown causing cmd.exe to launch with suspicious cmd c
Postby Mr T » Sun Jan 11, 2015 3:44 am
1837308050
Looks like some malware or fragment thereof. Run CCleaner and clear your temp folders. Also clear your browser (s) cache. Run disk cleanup from the hard drive properties. Download and install free Malwarebytes antimalware, update it. Boot into SAFE MODE and run Malwarebytes. It can throw up things not thrown up in normal mode.
Postby Karlsweldt » Sun Jan 11, 2015 7:04 am
If some unknown program or process is not desired in the Registry, Hijack This should note it. Do only a "scan".
A Windows feature called msconfig can be used from the 'run' prompt. All the system "vitals" are listed there.. tools, configurations, processes, programs for auto-start and manual launch. Go with 'selective start' if wanting to disable certain features or programs.. but use caution with some processes, or the system may not be stable.
Do as Mr T recommends.. but disable the 'restore' feature of Windows before doing so. If not done, Windows may undo all your efforts on the next normal boot! After ensuring all is good, then reactivate the 'restore' feature.
Postby joe_devore » Sun Jan 11, 2015 4:48 pm
I always keep a clean machine, I already got rig of any files in that directory ( I ended up with something one time when I forgot to enable the direct download link on Source Forge (its down-loaders are pushing unwanted garbage)...
anyways I immediately stopped it and cleaned it out I like Spybot S&D =D.... this might be something else...
So I reinstalled some of my drivers (all but the mobo drivers) again in-case I had broke something.. no apparently not that either....
I have preformed manual search of the registry, and used AutoRuns it cant seem to find a entry point
TDSSKiller SCANNED boot records that IS CLEAN too...! so its not loading from there.....
I keep a copy of "Kaspersky Rescue Disk" on hand just OI don't have any burnable cds right now... :(
ho ho ho I found something....
Uninstall C:\WINDOWS\system32\tscupgrd.exe
claims to be a m$ file but is not digitally signed..
v5.2.3790.1830 (srv03_sp1_rtm.050324-1447)
Setup Custom Action Dll
© Microsoft Corporation. All rights reserved.
custom.dll
all three entries were in RunOnce folders, 1st one was in the users_default and the other two entries were in two different user account...
perhaps remnants....
I have just removed them, (found them thx to Spybot S&D's autostart..) reboot see ya on the other side!
UNKNOWN_cmd_start_Possible found.txt.rar
(448 Bytes) Downloaded 41 times
joe_devore
Postby Karlsweldt » Sun Jan 11, 2015 5:15 pm
A lot of confusing reference links for that "tscupgrd.exe".
It is a Setup Custom Action Dll file. Supposed to be in the WINDOWS\system32 folder.
If anywhere else, may not be authentic. It could have been installed by Windows during setup, or by another program.
Some links note it is part of an executable process for Windows programming.
Some links note it as possibly a virus version.
Some links note it should be removed. Some not.
Some links note it is not harmful to the OS. Some do.
The description in this link may be of interest.. http://www.file.net/process/tscupgrd.exe.html
Postby joe_devore » Sun Jan 11, 2015 5:53 pm
nope that didn't stop the cmd from loading.... with that cmd line string.....
sfc /scannow didn't report anything either...
its useless comparing only to the older originals on the PS cd...
joe_devore
Postby evasive » Mon Jan 12, 2015 3:03 am
You seem to have an infection called FarBar. Let me check on how to get it out properly.
Postby evasive » Mon Jan 12, 2015 4:17 am
Postby joe_devore » Mon Jan 12, 2015 6:21 am
evasive wrote:You seem to have an infection called FarBar. Let me check on how to get it out properly.
Eyy Evasive =D thx..
I attached the scanner results.... it did not generate a fix file so it does not appear to be the FarBar....
plus I included a SysInfo report as well as a Speccy Report..
I have Daemon-tools Lite and SPTD installed among other programs which if not caused me problems...
as far as plugins and etx for IE all are disabled except for the Spybot plugin but then again I I never use IE, except for getting windows updates in the past...
FireFox FOREVER ^_^ and my ext and plugin lists are clean except for the plugins I use every single day for years, without issue
I did a quick scan of the C: for loose .JS and .vb scripts didn't find anything suspicious at a glance...
other then some Mozilla jvm .js files in a few extracted temp folders...
Farbar Recovery Scan Tool__Scan Results (no fix list)....rar
archive includes Farbar Recovery Scan, MSInfo report and Speccy Report....
(84.44 KiB) Downloaded 42 times
joe_devore
Postby joe_devore » Mon Jan 12, 2015 6:29 am
I have noticed something else odd
C:\WINDOWS\Debug\UserMode\ChkAcc.log
I don't remember this before...
but I was using Windows XP Pro SP3 32bit for the longest time....
since WinXP-Pro-64bit is based on Windows Server 2003... its only natural its doing things different
same with the security tab in MS Event Viewer ( I like the XP version its B.E.T.T.E.R. then the Win7 on and not as complicated)
its showing a a lot more activity same reason as above (WinServer2k3) I guess... that is I don't recall seeing anything suspicious...
going to do a reboot now have /bootlog enabled... to try and catch this...
joe_devore
Return to Tech Support
