It is currently Mon Jan 21, 2019 8:09 am
PostPosted: Sun Aug 08, 2010 11:41 pm
I can no longer login to windows unless i'm in safe mode. Whenever i tried to login normally I get a stop error, as follows:
IRQL_NOT_LESS_OR_EQUAL
0x000000D1 (0X3D10047F, 0X00000002, 0X00000000, 0X88D3F0F)
SYSTEM SPECS: Intel Pentium 2.3Ghz Dual Core, 2Gig PC2 6400 RAM, 300gig Seagate HDD, Asus P5N32-SLI Premium motherboard.
Any suggestions as to what is causing the error?
PostPosted: Mon Aug 09, 2010 12:58 am
the <whateverdrivername>.sys that is shown in the same screen. installed any new drivers/updates/software or hardware recently?
PostPosted: Mon Aug 09, 2010 5:26 am
Could be several reasons for this:
0x000000D1 DRIVER_IRQL_NOT_LESS_OR_EQUAL
The system attempted to access pageable memory using a kernel process IRQL that was too high. Drivers that have used improper addresses typically cause this error.
Note: Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL messages are very similar to 0x000000D1 DRIVER_IRQL_NOT_LESS_OR_EQUAL messages and the same troubleshooting principles apply. If you cannot resolve your 0x000000D1 DRIVER_IRQL_NOT_LESS_OR_EQUAL then try the 0x0000000A IRQL_NOT_LESS_OR_EQUAL section.
On a Microsoft Windows XP-based computer that is using certain network adapter drivers and certain host firewall software, you may receive a Stop 0xD1 error message that resembles the following:
STOP 0x000000D1(parameter1, parameter2, parameter3, parameter4)
HTTP.SYS
Note: In this message, the parameters that are represented by parameter1, parameter2, and parameter3 may vary.
Stop error message when you set the ConnectOnRequestedInterfaceOnly registry entry to 1 on a computer that is running Microsoft Windows XP:
"STOP 0x000000D1 DRIVER_IRQL_NOT_LESS_OR_EQUAL"
When you set the ConnectOnRequestedInterfaceOnly registry entry to 1 on a computer that is running Microsoft Windows XP, you may receive a Stop error message that resembles the following:
You receive a "STOP 0x000000D1" error after you create a network bridge on a computer that is running Windows XP
Consider the following scenario:
•You install two network adapters on a computer that is running Microsoft Windows XP.
•You create a network bridge that uses both of the network adapters.
•You install network driver interface specification (NDIS) intermediate drivers on the computer.
In this scenario, you may receive a Stop error message that resembles the following:
STOP 0x000000D1 (parameter1, parameter2, parameter3, parameter4)
Error message when a Windows XP SP2-based multiprocessor computer uses driver Battc.sys: "STOP 0x000000D1 DRIVER_IRQL_NOT_LESS_OR_EQUAL"
When you work with a Windows XP Service Pack 2-based multiprocessor computer, you may receive an error message that resembles the following:
Stop error message on a Windows XP SP1-based computer: "STOP 0x000000D1"
On a Microsoft Windows XP Service Pack 1 (SP1)-based computer that has certain wireless network devices installed, you may receive an error message that resembles the following:
DRIVER_IRQL_NOT_LESS_OR_EQUAL ar5211.sys
Note: The parameters that are represented by parameter1, parameter2, and parameter3 in this message may vary.
Stop 0x000000D1 Error Message When You Turn Your Computer Off
When you shut down your computer that has one or more universal serial bus (USB) devices attached to it, you may receive the following error message on a blue screen:
Stop 0x000000D1 (0x00000040, 0x00000002, 0x00000000, 0xfc96a9dc)
"STOP 0x000000D1 IRQL_NOT_LESS_OR_EQUAL Kbdclass.sys" Error Message When You Try to Shut Down the Computer
When you try to shut down your computer, you may receive a STOP error message on a blue screen that is similar to the following:
STOP 0x000000D1, (0x0000002b, 0x00000002, 0x00000000, 0xEEEE1b01)
IRQL_NOT_LESS_OR_EQUAL Kbdclass.sys.
After you receive this error message, the computer restarts.STOP: 0x000000D1 (0x0200000c, 0x00000002, 0x00000000, 0xf617c2c6)
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
You receive a "Stop: 0x000000D1" error message after you establish a VPN connection
After you establish a virtual private network (VPN) connection, your computer stops responding unexpectedly. You receive the following Stop error message:
You could have errors on your hard drive (try defrag)
A bad stick of memory (try just one stick of mem)
Or it could be a virus. (Run Malwarebytes)
https://store.malwarebytes.org/342/cook ... duct=29945
Paul
PostPosted: Tue Aug 24, 2010 10:47 am
Evern after removing all extra hardware, ie Video card, sound card, DVD-ROM, DVD Burner. In all I only had the Mobo, HDD, PSU, running and the error still came up. I tried a repair install of xp and It just made it worse, couldn't even get into safemode. In the end, had remove the partition, and create a new one and reinstall xp. It seemed to help. Its been a week and a half and no problems. Thanks for all the help. These types of errors are sooooo annoying.
Kevin
PostPosted: Tue Aug 24, 2010 11:56 pm
if you have some kind of deeply buried software error, the only "solution" is a full reinstall. To shorten the time needed for that i tend to make an image after the initial windows install, after the first round of updates and after the first round of installation of the major apps and plugins. If something goes wrong during the process I don't have to start from scratch. yes this means you need an extra harddisk you can connect to the USB port or whatever. But that should be available for backup purposes at any time anyway.
PostPosted: Wed Jul 06, 2016 5:09 am
having the same problem
PostPosted: Wed Jul 06, 2016 6:54 am
What is the .sys file that generates the error
-Wrapped Around Your Fingers-
-The Police-
PostPosted: Wed Jul 06, 2016 2:02 pm
looks like a bot to me. albeit one that has been sleeping for a long time.
PostPosted: Thu Jul 07, 2016 6:07 am
thansk for reply
here's is thing now
i search this problem on google and found a post
about this driver related problem as you can see
and they told me to analyze the drivers name just like you said rascard2007
so found its a athw8x.sys driver who's creating the problem
so can you help to fix this particular driver
plz help i having some school project to make and tomorrow is the last date
thanks for your reply
PostPosted: Thu Jul 07, 2016 3:22 pm
That "athw8x.sys" appears to be part of the Qualcomm LAN wireless driver package. Should be in the Windows/System32/Drivers folder.
This link refers to Win 8 problem, but may be of interest..
http://www.eightforums.com/bsod-crashes ... x-sys.html
Users browsing this forum: MegaIndex.ru [Crawler] and 3 guests
