Mobo change causing Windows startup problem!!!!!
Postby charlesp123 » Thu Nov 14, 2002 12:29 pm
I swapped a troublesome mobo with a KG-7 Raid board. Everything seems to be working fine except that the Windows 98SE takes forever to start.
What's causing the Windows to start so slow? And what should I do to fix this problem?
(Sometimes you just wanna bang your head against the wall!)
charlesp123
Postby evasive » Thu Nov 14, 2002 12:36 pm
If the original board had another chipset you are facing a windows reinstall. Start backing up data.
Return to Tech Support
Users browsing this forum: Baidu [Spider], Google [Bot], YandexBot [Bot] and 1 guest
