It is currently Mon Sep 24, 2018 6:15 am
 Post subject: M590 motherboard
PostPosted: Thu Nov 14, 2002 12:19 pm
I would like to upgrade my video card. The M590 has an integrated card. Is there a way to disable the integrated card so the motherboard will recognize my new card.
PostPosted: Thu Nov 14, 2002 12:25 pm
You should be able to do it in BIOS. Go in there and look around for an area called "Integrated Peripherals" or something like that - you should be able to disable it there.
PostPosted: Thu Nov 14, 2002 12:31 pm
If you leave memory slot 1 empty the onboard VGA cannot initialize and the inserted VGA should take over IIRC
no jumper, no bios setting. checked.
PostPosted: Thu Nov 14, 2002 12:44 pm
Oh bummer. Sorry - my mistake :oops:
PostPosted: Thu Nov 14, 2002 12:59 pm
np. weird board. weird manufacturer also.
