It is currently Sun Sep 23, 2018 4:59 am
 Post subject: Wiring and no post
PostPosted: Wed Nov 13, 2002 11:51 pm
In the ECS K7s5A manual it says the Power sw wire goes on pins 1 and 3.
Doesnt work for me. It does however turn on if it's on pins 5 and 6. weird.
But when i turn the dang thing on the monitor light turns green then orange then green again and back orange, over and over. (with no display) The video card is good, i just tried it on another puter.
Does anyone have any ideas? Any help is appreciated. Thank You.
Source_ERROR :?
PostPosted: Thu Nov 14, 2002 1:25 am
Welcome to the Mother Board!
Are you getting the single beep when the unit turns on? Hate to say it, but that mobo has been nothing but problems for most people. Make sure that all of your connections are good and that the video card and ram are seated all the way in. 8)
The Gift of Healing
Conscious Energy Meditation
PostPosted: Thu Nov 14, 2002 1:48 am
Wasn't there something at Newegg about the manual being wrong for that motherboard? There was a link to downloaded corrected version.
Check and recheck the Ram seating and the video card, it doesn't take much to knock it out enough to cause problems.
I took the CD-rom out of my system to put a DVD-rom in it's place. I didn't think I even touched the ram or video card. But sure enough when I turned my computer back on I had done something to displace the video card. Then after adjusting video card the RAM was goofy. Took RAM module out and reseated and all is well with the world again. :)
Teddy1
Abit IC7
Pentium 4 2.4MHz 800 fsb
512 mg Corsair DDR 3200 Twin XMS
80 gig Samsung regular IDE
Asus 4200 8X 128MB
Soundblaster Audigy Gamer
Lite-on DVD
Lite-on CD/RW 52x24x52
Viewsonic E70f
PostPosted: Thu Nov 14, 2002 9:33 am
thanx guys, i'll mess with it some more.
PostPosted: Thu Nov 14, 2002 11:14 am
Use the pinout as stated on the board itself near the connectors, the manual is goofed up. HWJ had a posting about this in the Tech Forum but that one was lost during one of the less-than-welcome visit of some Brazilian kiddies...
PostPosted: Thu Nov 14, 2002 11:40 am
I'd bet money Evasive is right.
PostPosted: Thu Nov 14, 2002 11:57 am
Evasive is correct.
Ignore the wiring diagrams in the manual. follow the Pinouts that are printed on the motherboard itself.
You should be up and running after that.
PostPosted: Thu Nov 14, 2002 8:50 pm
thanx
