It is currently Fri Sep 21, 2018 12:46 am
PostPosted: Wed Nov 13, 2002 8:31 pm
Hey all, I just bought a new case. Switched everything over. Checked and double checked all connections and fired it up. All fans run, HDD led is constantly lit but HD does nothing. No beeps, No video.
I am seriously bummed :cry: ! I was so excited about this new case. I hid all wires, cleaned all my fans and now I get this knockout punch to the jaw. I have spent all night trying different stuff.
I tried a bare minimum start-up with the same results. I never removed the CPU either. I tried switching around sticks of ram. Tried clearing cmos.
What else could I possibly try? I have sent a trouble call to ECS, God only knows how long that will take. Warranty still good to FEB.
Thanks in advance all,
AMD 2800+ Barton @ 190x12.5 W/SLK900A / Soltek SL-75FRN2 Ultra 400 MOBO, 1GIG BLACK DIAMOND PC3200, WD 7200rpm 80 GIG HD, 9800np, AUDIGY2 , ENERMAX 350WATT P/S, 52X CDROM,SAMSUNG 48X24X48 CDRW, MSFFB2 JOYSTICK, KLIPSCH PROMEDIA 2.1.
PostPosted: Wed Nov 13, 2002 9:20 pm
Well assuming there is no short from the new case touching the motherboard anywhere near a non-mounting hole, it would have to be wiring somewhere that is going haywire. Could be a connector that is not fully engaged, or maybe striped and grounding on the chassis. No beeps, no video with fans running could point to a faulty video card. I know, I destroyed my Radeon 8500 this week by flashing it with an aparantly a faulty bios.
PostPosted: Thu Nov 14, 2002 2:54 am
Thanks for the reply Johnny. I really dont think its the video card. I am very sorry to hear about yours man. I know you did a good bit of research before you bought that thing. If it is grounding out somewhere, I have no idea where. One thing I havent tried is switching cables. I will try switching my IDE cables today after work and see what happens.
I hate to say this but I think I may have cracked it while putting on the main power harness. That thing is really stiff. I took the board off and inspected it closely. I can't see any cracks or chips. But when I put the slight pressure on it i hear a creaking or cracking sound. By the way, Would a bad video card really cause No beeps?
PostPosted: Thu Nov 14, 2002 3:31 am
Drunken Master
not sure on the beeps. First thing I would try is running the basic setup outside the case to see if it will post.
Use the motherboard box to set the board on. If it boots and works then try installing to case again, it might have been screwed in too tight...
Anyway something to try. If it will not boot while outside case then someone else will have to take you step by step. That is beyond me.
Hope this helps.
PostPosted: Thu Nov 14, 2002 9:19 am
I had a K7S5A that for some reason took an occasional BIOS clear to boot up. Try using the jumper to clear the bios and see if it boots for you.
I replaced mine with a MSI KT3 Ultra2. Just wish it had onboard NIC.
A rectangular bear is just a polar bear after a coordinate transform. - I dunno who
PostPosted: Thu Nov 14, 2002 9:26 am
Noggin that AVTAR is frightening!!!!! 8O 8O 8O
PostPosted: Thu Nov 14, 2002 10:12 am
That's him on a good day...check him out on a bad day! ;-)
John D.
________
Avandia recall
PostPosted: Thu Nov 14, 2002 10:25 am
yoojie and JohnCD, even as freaky as Noggin's avatar is. please keep on the subject at hand. This tread is in the tech support forum not the water cooler... If you want to make a comment on asn avatar please post in the water cooler or general forums.
Toby
Compaq-Fu Master
PostPosted: Thu Nov 14, 2002 10:26 am
No, I don't want to make a comment on an avatar. Thanks anyway.
JOhn D.
________
Think Mill
PostPosted: Thu Nov 14, 2002 11:15 am
LEd constant lit, no HD reaction = data cable connected backwards.
Users browsing this forum: Google [Bot] and 6 guests
