Temp meter for PC
Temp meter for PC
Postby yoojie » Wed Nov 13, 2002 7:46 am
Can anyone let me know what is a good to decent temp meter I can use to add to my PC? Dont want to spend to much but want to see what my temps are running at.
Need mfg names and a price if you know it.
THANKS!!! :D
yoojie
Postby uniquemale69 » Wed Nov 13, 2002 11:46 am
THE SITE IS HERE:
http://www.dealsonic.com/thera1hariih.html
DETIALS:
Thermaltake A1278 Hardcano II Hard Disk Drive Cooler w/LCD Temp Monitor
Our Price:$25.00
Availability: Usually ships the next business day.
Part#: DSTTA1278
FedEx Ground Shipping: $5.95
FedEx 3 Day Saver: $7.95
uniquemale69
Postby yoojie » Wed Nov 13, 2002 11:54 am
Yeah I saw that one, but the problem is that I have 2 HDD's and am not sure if I can get the IDE cable to reach........
I was hoping for just a sensor.
Have you used this one yourself? Do you have to HDD's? How did you get it to work?
yoojie
Postby Timmeh » Thu Nov 14, 2002 1:19 am
Not sure whether you wanted a system sensor or HDD sensor.
Have you been here?:
http://www.hddtemperature.com/
Blew me out when I found my IBM 45g had a sensor built in. I just go to this site and run the check when I want to know the temp.
Unfortunately the freebie software is only for a single drive.
Timmeh
Postby Mr T » Thu Nov 14, 2002 12:04 pm
Try here if you live in the US:
http://www.highspeedpc.com/
Return to Tech Support
Users browsing this forum: Bing [Bot], YandexBot [Bot] and 2 guests
