ECS K7S5A Problems!
ECS K7S5A Problems!
Postby netdevil85 » Wed Nov 13, 2002 5:23 am
I have just upgraded my system. Added a new motherboard (ECS K75SA) and an AMD Duron 1.3ghz. I now have the following problems...
1 - Windows XP Pro will note install - I keep on getting a file copy error message.
2 - Sometime my motherboard does not detect my DVD and CD-RW drives at boot up.
Here is my spec...
AMD Duron 1.3ghz
ECS K75SA Motherboard
10gb HDD - IDE
100mb ZIP - IDE
16x 48x DVD - IDE
8x 4x 32x CD-RW
512mb PC133 ram
SB Audigy Platinum - PCI
ATI Radeon VE 32mb DDR
56k modem - PCI
10/100mb Netgear NIC
Any ideas?
Thanks,
Alex Clarke.
netdevil85
related??
Postby forests » Wed Nov 13, 2002 6:00 am
Did you try out the latest Bios from the ecs website. that should help solve the dvd and cd-rw problem. while the windows xp problem could be related to teh disappearing dvd or cd-rw, xp problem may be a corrupted windows xp cd itself. you did not mention the psu.
forests
Postby yoojie » Wed Nov 13, 2002 6:13 am
Do you have the correct jumper settings on the CD roms? Try using just cable select on both. Or the reverse if you are having probs now.
Also make sure you have a VALID copy of the OS. Seen that copy thing on a bad copy of the CD.
yoojie
Postby Johnny Mnemonic » Wed Nov 13, 2002 7:44 am
Sounds like the IDE cable on your CD-ROM is going south, or not connected securely.
0100101001001101
Johnny Mnemonic
Postby netdevil85 » Wed Nov 13, 2002 8:16 am
Ok. This will really begin to puzzle you...
When I said that the motherboard sometimes does not detect my DVD and CD-RW drives I meant this...
Sometimes I will turn my PC on and it will find the following IDE stuff...
HDD
ZIP
DVD
CD-RW
...Or it will only find this...
HDD
ZIP
It will then proceed to load Windows 98SE without my DVD or CD-RW drives!
netdevil85
Postby yoojie » Wed Nov 13, 2002 8:24 am
Could be the cables or the drives.....
Pull 1 drive out and see if everything loads.
yoojie
Postby Mr T » Wed Nov 13, 2002 9:01 am
Do a minimal boot to get XP on, check your IDE cables are in tight (minimal boot = m'board, cpu =hsf, 1 stick of ram, 1hdd, 1cdrom, 1 video card and floppy).
Re: ECS K7S5A Problems!
Postby Southwind25 » Wed Nov 13, 2002 10:17 am
netdevil85 wrote:I have just upgraded my system. Added a new motherboard (ECS K75SA) and an AMD Duron 1.3ghz. I now have the following problems...
Here is my spec...
AMD Duron 1.3ghz
10gb HDD - IDE
100mb ZIP - IDE
16x 48x DVD - IDE
8x 4x 32x CD-RW
512mb PC133 ram
56k modem - PCI
Any ideas?
Thanks,
Alex Clarke.
I've had some problems with Netgear lan cards being compatible with some hardware. You shouldn't need it because the ECS board has onboard lan.
Southwind25
Postby netdevil85 » Wed Nov 13, 2002 2:13 pm
My motherboard is the version without the onboard LAN. Anyway... I have tried removing the card and doing a minimal boot, but I still get the same problem!!
netdevil85
Postby Noggin » Thu Nov 14, 2002 9:22 am
I had MASSIVE problems running XP on my K7S5A, it HATED my IDE controller and gave me all kinds of errors. If I upgraded from win9x it would work fine... until it did that "checking hard drive for errors" then it would give me some type of blue screen error.
If I tried doing a clean install, I'd get the blue screen error as soon as I selected a partition.
I flashed the BIOS and it began working. But it required me to use the jumper to clear the bios about half the time I booted. I replaced that ECS board with a MSI one. Only thing I miss is the onboard NIC.
A rectangular bear is just a polar bear after a coordinate transform. - I dunno who
Noggin
Return to Tech Support
Users browsing this forum: AhrefsBot [Bot], DotBot [Bot] and 3 guests
