invalid clockspeed
invalid clockspeed
Postby sydox138 » Tue Nov 12, 2002 6:24 pm
I have a amd athlon xp 1500+ chip, but it is only running at 1000mhz's. In the bios i can change the fsb/clockspeed ratio. I have three options 100/100, 133/100, 133/133 respectivly. the only one that is stable is 100/100. my motherboard is an ecs k7s5a v1.0x and says it takes the whole line of xp chips, and can be 200 or 266 fsb. i also have volcano 6 fan and the temp of the cpu is around 50c or 83f degrees. when i try to put it on a ratio other than 100/100 it goes to right before the os starts and locks up. also when i have it on 100/100 the startup before the bios says Athlon 1000Ghz, and when i have it on another is says athlon xp 1500+
Any info would be appreciated.
amd athlon xp 1500+
ecs k7s5a v1.0x
volcano 6
384 megs sdram pc133
pine 64 meg video
win xp 3500 (upgraded from a win 98 shell)
sydox138
Postby Wookie8662 » Tue Nov 12, 2002 10:25 pm
I have 3 of these motherboards.
One is running a 1.2 duron, another a 1.13 TB, third has an XP1600.
The XP should boot and run at 133/133.
First thing to do is make sure your bios memory settings are set to NORMAL. If that doesnt work, then try the SAFE setting. These boards are very picky about the memory settings. Also make sure you are running PC2100 if using DDR, or PC-133 if running SDRAM.
The second thing that I would take a look at is the power supply in your system. It should be at minimum a 350w supply, and I would recommend a 400w supply.
If all this fails, check out this site for some help:
http://www.geocities.com/mrathlon2000/
Good luck,
Wookie8662
Wookie8662
Postby Mr T » Tue Nov 12, 2002 10:42 pm
Remove one stick of memory and then adjust your clock speeds, the 2 sticks could be unstable together!
Postby Wookie8662 » Tue Nov 12, 2002 10:53 pm
Ah, I didnt see that in your specs.
That could very well be the culprit.
Good eyes, Mr. T! :)
Wookie8662
Return to Tech Support
