It is currently Sun Sep 23, 2018 2:32 pm
 Post subject: onboard graphics
PostPosted: Tue Nov 12, 2002 5:15 am
if I want to add a agp graphics card to my an266-vm M/B do I have to disable anything in the BIOS
PostPosted: Tue Nov 12, 2002 4:01 pm
I tried to look at the manual for your mobo at asus but the server seemed down. Anyway since its got integrated nvidia graphics I would say its a safe be that you need to disable it. If there isn't an option in your bios then check for a jumper on your mobo to disable it.
If it aint broke, fix it till it is
PostPosted: Wed Nov 13, 2002 3:43 am
Thank's for the reply . The manual does not address how to disable the vid I guess I will try to email Asus . I Know GOOD LUCK right. There tech service is not very good
PostPosted: Wed Nov 13, 2002 2:14 pm
Browse through all the settings on your bios. There might be something there about the onboard video. If not there should be a jumper that you could change to disable it.
PostPosted: Wed Nov 13, 2002 2:35 pm
Ok Im pretty sure I found the answer for you...
Look for the PCI configuration page under the advanced options in your bios.
There is a selection for Primay VGA Bios. The options are AGP VGA Card and Onboard VGA Card. Select AGP VGA Card and that will disable the onboard video and allow you to use your agp card.
PostPosted: Wed Nov 13, 2002 8:11 pm
Hey Chulo thanks a lot took a look and there it was will now buy my MSI GF4ti4200again thanks a lot :)
