p4s8x random restarts
Postby m3 » Mon Nov 11, 2002 8:48 pm
i built my system about 3 weeks ago and everything has been oh so nice.
until recently yesterday, I started getting random restarts? what can I do about this?
p4s8x
2.4 p4
512 mb pc2700 corsair
40gb x 2 7200 rpm ibm hdd
m3
Postby Valour » Mon Nov 11, 2002 8:50 pm
Try the new BIOS -- 1005.
-Jem
Valour
Postby m3 » Mon Nov 11, 2002 9:00 pm
where do i get it?
m3
Postby Grime » Mon Nov 11, 2002 9:33 pm
Your mobo should have come with a cd that has an update downloader on it....but...... since I'm so nice :wink: :
http://cgi.asus.com.tw/cgi-bin/dl.asp?f ... s8x004.zip
Windows XP Professional w/SP2
Abit IC7-MAX3
P4 2.6Ghz 800Mhz FSB w/HT
1gb Mushkin Level II PC4000
ATI Radeon 9800 XT
SB Audigy Gamer
2x WD Raptor 10k rpm SATA w/ RAID-0
Sony DRU530A DVD-RW+RW
Zalman CNPS 7000-cu CPU Cooler
Grime
Postby Valour » Tue Nov 12, 2002 6:42 am
Just go to the Asus website... www.asus.com then click on the Pan-Asia (English) link on the left, then navigate the support menu to the downloads section and then to the BIOS... you want either the 1004 or 1005 (try the 1005 and let us know how well it works).
-Jem
Valour
Postby Staffa » Tue Nov 12, 2002 10:06 am
Where did you find the bios upgrade 1005? The latest I have seen is 1004...
I am hoping this will fix my problems with my motherboard.
Staffa
Postby Valour » Tue Nov 12, 2002 10:31 am
Staffa wrote:Where did you find the bios upgrade 1005? The latest I have seen is 1004...
The 1005 might still be beta. If there is a problem with the board, the 1004 will definitely fix it. The 1005 is supposed to be a new and improved 1004, I guess.
-Jem
Valour
Return to Tech Support
Users browsing this forum: AhrefsBot [Bot] and 6 guests
