Will Micro ATX mobo work fine in a Mid tower?
Postby bmcoastie_1 » Sun Nov 10, 2002 1:44 pm
Hi guys, Looking for a Mobo for the new system I am building for my mom. I am looking at the Biostar M7VIG Motherboard for AMD Socket A Processors.
I just realized it is a micro atx board. Is the only difference that it only has 3 pci slots and not 5? Will it fit fine in my Mid Tower case?
Thanks in advance,
AMD 2800+ Barton @ 190x12.5 W/SLK900A / Soltek SL-75FRN2 Ultra 400 MOBO, 1GIG BLACK DIAMOND PC3200, WD 7200rpm 80 GIG HD, 9800np, AUDIGY2 , ENERMAX 350WATT P/S, 52X CDROM,SAMSUNG 48X24X48 CDRW, MSFFB2 JOYSTICK, KLIPSCH PROMEDIA 2.1.
bmcoastie_1
Postby Wyrm73 » Sun Nov 10, 2002 4:33 pm
It will fit just fine in most cases. Most of the time they have holes drilled for the several different boards. I put a micro ATX mobo in a normal ATX case with no problems (with mounting the mobo at least :D ).
Wyrm73
Return to Tech Support
Users browsing this forum: Qwantify [Crawler] and 1 guest
