A7V8X and XP2600 or XP2700
Postby Wolfman_11511 » Sun Nov 10, 2002 12:34 pm
can i put either of these processors in this board? and what CPU fan should I get?
In process:
AMD XP2200 (XP2600?)
Asus A7V8X w/raid (have)
MSI G-force 4Ti 4200 64MB (bang for the buck)
Samsung 512MB PC2700 DDR
80 Gig HD (No idea)
Antec 1040 SOHO W/400 (have)
CD/RW (?) any recommendations?
DVD rom (any 16X)
Wolfman_11511
Postby Happy Hillbilly » Sun Nov 10, 2002 7:50 pm
With a BIOS upgrade you can go up to the XP 2600. The HSF type depends on whether or not you plan on OCing. If you are gonna OC, you might want to consider the Volcano 7+ by Thermaltake.
Luke 6:31
Happy Hillbilly
Return to Tech Support
