It is currently Fri Feb 22, 2019 1:19 pm
PostPosted: Sun Nov 10, 2002 9:35 am
Processor: AMD 2100+ XP
MoBo: Asus A7V333
RAM: 256mb PC2100
Case: Enermax Neon/Window CS305
Sound: Onboard
Video: NVIDIA
Power Supply: Enermax 350W (Came with case)
OEM: Home build
OS: Windows XP Pro
Other hardware: Western Digital 80GB HD, Creative CD-ROM, Sony CD-R/RW
So here's the problem...I had a ANTEC SL350 power supply crap out on me earlier in the week. I verified that it was the power supply with another unit. So i buy a new case (I was a bit sick of the old one) with packaged power. Ever since then Windows XP Pro has been restarting or shutting down randomly. As you can imagine this has pissed me off significantly :evil: . I just want to be able to run the system without it shutting down.
So here's my question...should I replace the power supply that came with the case? If so what power supply would you recommend. Also, is it possible in loosing the power that damage was done to other components?
Thanks for the help!
Bob
PostPosted: Sun Nov 10, 2002 10:13 am
maybe your computer is rebooting because your cpu is heating up....you should try monitoring your cpu temp
PostPosted: Sun Nov 10, 2002 10:23 am
Temps have not gone above the threshold and are being monitored by ASUS Probe.
PostPosted: Sun Nov 10, 2002 7:16 pm
Yes - I've lost components due to bad PSUs and I've lost components due to a PSU that didn't supply enough power. Personally I like the Antec True Power series of PSUs and Enermax. Get at least a 400w this time to make sure you have enough power.
Good luck 8)
PostPosted: Sun Nov 10, 2002 8:17 pm
Definitely sounds like a PSU problem :( Gotta go above 400W
PostPosted: Sun Nov 10, 2002 8:55 pm
I have the same problem! Except first it was in Win98 SE, then I tried XP and still have the same problem. Mine reboots randomly, and freezes, but only if I set my CPU speed to 2533. It is a brand new P4 2.53Ghz, but I am forced to run it at 1900Mhz!! I'm pretty sure my PS is a Logic 460W, and brand new mobo (asus p4t33), video card, and ram (512mb samsung 1066Mhz RIMM4200). Could the problem really be my power supply? HELP?! :!:
Windows XP Professional w/SP2
Abit IC7-MAX3
P4 2.6Ghz 800Mhz FSB w/HT
1gb Mushkin Level II PC4000
ATI Radeon 9800 XT
SB Audigy Gamer
2x WD Raptor 10k rpm SATA w/ RAID-0
Sony DRU530A DVD-RW+RW
Zalman CNPS 7000-cu CPU Cooler
PostPosted: Sun Nov 10, 2002 9:11 pm
Yeah - PSUs, just like any component can be faulty right out of the box.
Oh and I said AT LEAST 400w. jsheinz is right - probably should go with more power with what you're running.
PostPosted: Sun Nov 10, 2002 9:19 pm
This is really strange. I was messing around with my external clock settings (it was crashing on anything between 105-133) and just for kicks I set it to 136, and... WALLA! suddenly no more crashing! Not to mention my 2.53 is running at 2.58 now (gotta watch tha temp though).
Abit IC7-MAX3
ATI Radeon 9800 XT
SB Audigy Gamer
PostPosted: Sun Nov 10, 2002 9:30 pm
Cool - maybe you found the problem. But YES - definitely watch those temps!!
Good luck 8)
PostPosted: Sun Nov 10, 2002 10:37 pm
?If it was CPU temp, the system would shut down and not restart, (ASUS C.O.P.), what brand of RAM have you got, 'tis the usual culprit in the random reboot arena for this board!? You could also have a bad contact, I would reseat everything esp. RAM and your video card.
