Checking MB
Checking MB
Postby bramx » Sun Nov 10, 2002 7:55 am
:? Is there any way to check whether or not a MB is operational??
Postby Happy Hillbilly » Sun Nov 10, 2002 7:27 pm
I believe there are machines that can test them at some computer repair shops for probably about the same amount that you could buy a new mobo for. I don't know for sure 'bout that.
The best way is to use compatible parts that you know works. CPU/Memory/HD/Video/Case w/PSU
Luke 6:31
Happy Hillbilly
Return to Tech Support
