It is currently Tue Feb 19, 2019 5:21 pm
 Post subject: PHP variable problem
PostPosted: Sat Apr 21, 2007 4:10 am
Hope you guys can help. I'm trying to set up a program on my site but whenever it reaches the same variable, it stops. The files are PHP. Basically, I have a folder in the root dir called /admin, and another folder called /English, which is set in my admin panel as my default language. The beginning of each document with the problem looks like this:
Quote:
<?php
include("../config.php");
include("adminlib.php");
$textpart = "eventtypes";
include("../getlang.php");
include("../$mylanguage/admintext.php");
tng_db_connect($database_host,$database_name,$database_username,$database_password) or exit;
include("checklogin.php");
The problem is, when the server parses the file in question, I get the following errors, which seem to indicate that when the line in bold above is parsed, it's not read properly by the server (the variable $mylanguage seems to be missing):
Quote:
Warning: include() [function.include]: Unable to access ..//admintext.php in /usr/local/psa/home/vhosts/mysite.com/subdomains/family/httpdocs/admin/index.php on line 6
Warning: include(..//admintext.php) [function.include]: failed to open stream: No such file or directory in /usr/local/psa/home/vhosts/mysite.com/subdomains/family/httpdocs/admin/index.php on line 6
Warning: include() [function.include]: Failed opening '..//admintext.php' for inclusion (include_path='.:') in /usr/local/psa/home/vhosts/mysite.com/subdomains/family/httpdocs/admin/index.php on line 6
Any ideas? I'm not terribly brilliant at PHP so I might be missing something silly and obvious.
PostPosted: Sat Apr 21, 2007 4:40 am
basically the problem is the setup of the file structures.... As it stands not the code is trying to find a file that does not exist....
Not sure how to go about it, but:
Code:
Does not physically exist. The language folder is a seperate folder all together, and the admin file is not in that directory. I understand what you are trying to accomplish but do not know the coarse of action to get there.
Compaq-Fu Master
PostPosted: Sat Apr 21, 2007 4:44 am
If I change ../$mylanguage/whatever.php to ../English/whatever.php, then it finds the folder it wants. The problem is that I want dynamic language choice, not to hardcode everything to be English.
PostPosted: Sat Apr 21, 2007 5:29 am
Like I said I know what you want to do just dont know exactly how to do it.
But the problem is the way the code is being interpited, its trying to find a page in a folder named $mylanguage and not interpiting the $mylanguage as English.
Compaq-Fu Master
PostPosted: Sat Apr 21, 2007 11:43 am
Incidentally, the PHP retrieves the language via this method:
Quote:
<?php
@ini_set( "session.bug_compat_warn", "0" );
session_start();
session_register('session_language');
session_register('session_charset');
$session_language = $HTTP_SESSION_VARS[session_language];
$session_charset = $HTTP_SESSION_VARS[session_charset];
if( $session_language )
$mylanguage = $session_language;
elseif( $HTTP_COOKIE_VARS[tnglangfolder] ) {
$mylanguage = $HTTP_COOKIE_VARS[tnglangfolder];
$session_language = $HTTP_SESSION_VARS[session_language] = $mylanguage;
$session_charset = $HTTP_SESSION_VARS[session_charset] = $HTTP_COOKIE_VARS[tngcharset];
else {
$mylanguage = $lang ? $lang : $language;
$session_language = $HTTP_SESSION_VARS[session_language] = $language;
if( !$session_charset )
$session_charset = $HTTP_SESSION_VARS[session_charset] = $charset;
PostPosted: Tue Apr 24, 2007 1:32 am
I think I have a solution - apparently it's looking for the webserver root and not the account's root directory, so I need to append this before the include:
Quote:
$_SERVER['DOCUMENT_ROOT'].
Ie:
Quote:
include ($_SERVER['DOCUMENT_ROOT'].'/text.php');
I'll give it a try now...
PostPosted: Fri May 11, 2007 3:15 pm
Dunno if you have solved your problem.
Line 6:
Code:
Should proberly be:
Code:
include("../".$mylanguage."/admintext.php");
PostPosted: Sat May 12, 2007 1:04 am
Thanks, I'll give that a try at some point this weekend...
