It is currently Tue Dec 11, 2018 4:22 am
 Post subject: Comparison of schemas
PostPosted: Wed Jun 07, 2006 8:46 am
I have the need to check two different versions of the same XML schema. Looking for an easy way to accomplish this. Currently I use IE and/or XML Spy, open both versions of the schemas, and go back and forth looking at the two..........
Does anyone know of a tool that can do this, pointing out the differences?
PostPosted: Wed Jun 07, 2006 10:00 am
if you're just basically checking the file differences between them, then i recommend getting PSPad. it's free and has a built-in comparison tool.
http://www.pspad.com/
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Fri Jul 14, 2006 12:43 pm
I use windiff
