It is currently Mon Dec 10, 2018 8:41 pm
 Post subject: REXX SQL ver. 2.3?
PostPosted: Fri Mar 31, 2006 10:24 am
Can anyone help me locate Rexx SQL version 2.3 for MYSQL for OS2 4.0 or Ecomstation 1.2 ?
Currently using 2.4 and am unable to load the functions from the Rexx sql library.
Thanks
Ian
Help humanity join Motherboards.org Folding
IBM X440 IBM Netfinity x 2
Abit NF7S replaced by DFI Lan Party
2600+Mobile@2540
2x1Ghz OCZ
MSI RX9800pro R360
Aardvark ProQ10
Skyhawk Aluminum
PostPosted: Mon Apr 03, 2006 4:05 pm
Not that anyone uses REXX or OS2 but....I found the problem.
The newer dll's in MySQL are renamed and even the newest version of REXX hasn't accounted for that. So for all you people that are also using this obscure combination of SW, I'm guessing most of you :wink: Get an older version of MySQL and you too will be able to load the functions from the Rexx sql library.
Well at least it's free vs Oracle or DB2 .
And remember REXX rhymes with The LEXX and that was a great SciFi.
2600+Mobile@2540
2x1Ghz OCZ
MSI RX9800pro R360
Aardvark ProQ10
Skyhawk Aluminum
