It is currently Mon Oct 22, 2018 6:54 am
PostPosted: Wed Mar 15, 2006 7:20 am
Can anybody help?
I'm trying to read in ints from a txt file, but the ints need to be assigned in a special way if the word start or goal is on the next line. How can I read the line and if the next line is one of the words use the ints?
Code:
else while(inReader != null){
                    try{
                        inFile.mark(3);
                        inFile.readLine();
                        if (inFile.readLine() == "Start"){
                            inFile.reset();
                            String pos = inFile.readLine();
                            char i = pos.charAt(0);
                            char j = pos.charAt(2);
                            inFile.readLine();
                            inFile.mark(3);
That's what I'm trying at the moment. Any ideas?
 Post subject: more information
PostPosted: Tue Mar 28, 2006 12:07 pm
Not sure I understand what you are trying to do.
Can you provide an example of the type of data in your text file?
PostPosted: Tue Mar 28, 2006 12:09 pm
Well I've done it now, it was to read in numbers seperated by a space from a text file. I'm now working on a maze game built in java, nearly there now!
