It is currently Mon Oct 22, 2018 8:38 am
 Post subject: DIVS IN HTML
PostPosted: Sun Jan 29, 2006 11:09 pm
Hi
I am having trouble with some divs in HTML. The problem is basically when the content is too long it overlaps in the bottom.
You can see what i mean over here
http://vaniercollege.org/chrisostomos/TEMPLATE1/
Its where the text says OVER HERE on the page, that is suppose to be part of the content.
So basically the footer and every other part is suppose to go down.
The error only shows up in FIREFOX
Thanks for any input at all
Chris Vicatou
PostPosted: Mon Jan 30, 2006 8:25 am
Use the HTML language to place the text exactly where wanted. Use the line/column configuration.
Example from HTML editor handbook:
<HEADER>
<STYLE>
DIV.Beetles {bacground: #FFFF20; font-style: Arabic}
</STYLE>
</HEAD>
</BODY>
<DIV CLASS="Beetles">
<H2>Beetles</H2>
{topic or source}
PostPosted: Sat Feb 18, 2006 12:06 am
Firefox, Mozilla etc isnt forgiving with bad coding. IE bends rules and works out of validated code restraints (thats a bad thing).
Are you familiar with validation?
Run your html through here.
http://validator.w3.org/
It can help you code and is a great tool.
PostPosted: Sun Apr 02, 2006 6:46 am
Another option is to create an image map 800/600 with adjustable sides. I'm drawing a blank... Like a blank frame. See here
http://www.aibuilt.com/mastic.html
This is a site I am still working through. I have had the same problem when setting up websoft DB's.
Help humanity join Motherboards.org Folding
IBM X440 IBM Netfinity x 2
Abit NF7S replaced by DFI Lan Party
2600+Mobile@2540
2x1Ghz OCZ
MSI RX9800pro R360
Aardvark ProQ10
Skyhawk Aluminum
