It is currently Fri Feb 22, 2019 2:27 am
PostPosted: Sat Nov 26, 2005 9:50 pm
Hi
I am wondering how can i set the width of a drop down box in html.
Because it originally starts off empty and when i add stuff it changes size
Thanks
Chris Vicatou
PostPosted: Sun Nov 27, 2005 1:21 pm
So basically you want it to be a fixed with regaurdless if there are options or not in the drop down box?
Compaq-Fu Master
PostPosted: Mon Nov 28, 2005 8:26 am
Place your cursor point on the edge of the box outline. If the cursor changes to a double-edged arrow, you can "drag" the box to a new size. The box will automatically resize to show its contents. When you reselect the box, it should appear as last desired. Different function boxes will not be affected. A "normal" window box may appear in different locations, part of the "screen saver" intent. Does the upper right corner have the three "choice" boxes, for full-screen, minimalize, and close?
PostPosted: Mon Nov 28, 2005 8:51 am
so...wait...what are you using to code this? a plain text-editor or a WYSIWYG-type editor (i.e. dreamweaver, frontpage...)??
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Mon Nov 28, 2005 11:11 am
<select style="width: 250px;">
<option value ="volvo">Volvo</option>
<option value ="saab">Saab</option>
<option value ="opel">Opel</option>
<option value ="audi">Audi</option>
</select>
PostPosted: Mon Nov 28, 2005 11:18 pm
Thanks Olly
That worked perfectly!!!
