It is currently Thu Feb 21, 2019 10:24 pm
PostPosted: Tue Nov 22, 2005 8:17 am
1. With help of the below code excerpt explain what self re-writing code is?
2. Why can this be considered as a bad programming method?
Dim COLUMN_NAME as string
Dim inputValue as variant
R16;COLUMN_NAME is assigned different values (inputValue) and the below segment is iterated.
R30;
Dim libFileNo as integer
libFileNo = FreeFile
Open SQAGetDir(SQA_Dir_Scripts) & "library.rec" For Output As #libFileNo
call PCUtil_writeToTestLogger( "LOW", "library.rec file opened", C_DP_TAG )
Print #libFileNo, str( "global " & COLUMN_NAME & " as variant" ) Print #libFileNo, Print #libFileNo, str( "sub main" )
'$CStrings
Print #libFileNo, str( COLUMN_NAME & "=\"" & inputValue & "\"" )
Print #libFileNo, str( "SQALogMessage SQANone, \"" & COLUMN_NAME & "=" & inputValue & "\", \"COLUMN_NAME\" " )
'$NoCStrings
Print #libFileNo, str( "end sub" )
Close #libFileNo
callscript "library"
I have no clue so I thought Id ask :)
PostPosted: Wed Nov 23, 2005 9:54 pm
8O 8O
What coding language is that??? Nothing like I have ever seen before... 8O 8O
Compaq-Fu Master
PostPosted: Thu Nov 24, 2005 1:11 am
Toby B. wrote:
8O 8O
:mb_dontknow:: Shes in college and just asked if I knew any resources for help and I could only think of this website :mb_dontknow::
Other than that I know nothing :oops: But I could try asking :)
PostPosted: Thu Nov 24, 2005 4:04 am
http://www.processbuilder.com/swConstru ... bjects.htm
http://siebel.ittoolbox.com/groups/tech ... c-l/123660
Tried googling the first line in inverted commas.
Peace for its people,
Love in our lives,
Delight in the good,
Forgiveness for past wrongs,
And from now on a new start.
PostPosted: Sun Nov 27, 2005 1:48 pm
Uggggh. Ugly written VB.
PostPosted: Mon Nov 28, 2005 11:18 am
This is a good VB site
http://www.visualbasicforum.com/
