html help
html help
Postby Ghen » Tue Oct 11, 2005 3:20 pm
My host has a quirky method of disallowing access to file lists in folders with no index.html file.. Instead of showing Index of .... it loads a generic comcast.net page saying this user hasn't moved in yet.
I want an index file that just shows what is in the folder without having to actually write an html file and linking everything. In a perfect world it would also update itself every time I upload a new file to the folder. The thing is, I really have no idea how to do this without it being the tedious process of copy/pasting every name into a html file.
Ghen
Postby ~Rob » Tue Oct 11, 2005 3:23 pm
ok, you will hate me for this, but could I suggest php? It would be a lot easier I think.
That, or a redirect to the list of files, no, that wouldn't work...
~Rob
Postby Hardware Junkie » Tue Oct 11, 2005 3:55 pm
yeah it might have to be a dynamic script - I did come accross this once...
Way back in the day
Postby Hardware Junkie » Tue Oct 11, 2005 3:58 pm
Postby Hardware Junkie » Tue Oct 11, 2005 4:19 pm
Postby Toby B. » Tue Oct 11, 2005 6:16 pm
Check to see if your host allows the use of .htaccess files.... If so let us know and we can get you set up with a file to allow what you want...
Toby B.
Return to Programming
