It is currently Thu Oct 17, 2019 8:07 pm
 Post subject: Flash Drive Menu System
PostPosted: Sat Oct 08, 2005 5:16 am
What is the easiest way to call programs from a menu on a Flash Drive?
With a 1GB flash drive, I've got a few favorites like FTP client, E-mail, Backup and Sync software...but they're a couple of layers down the tree.
The problem is, of course, that plugged into one machine it's drive E: while it may be drive H: on another.
I tried to write to relative paths as I would on my website, but that didn't work. Of course, "shortcuts" won't let you write to relative paths...or will it?
dir1/dir2/program.exe
What's the best solution?
Anyone?
reader
_ _ _____ _ _
"There we were, lost in the Wilds of Afghanistan without a corkscrew. Forced to live for days on nothing but food and water."
W.C. Fields
PostPosted: Sat Oct 08, 2005 6:56 am
...answering my own post!
Found a Portable Flash Drive Menu system...called PStart.
http://www.pegtop.net/start/
Works very well, indeed. Inserted in an autorun.inf file, up it comes as soon as you plug in the USB drive.
A simple batch file will do the same thing, of course. It just won't be as "elegant!"
@echo off
echo Starting Thunderbird...
cd\
start CruzerMini\PortableApps\PortableThunderbird\PortableThunderbird.exe
reader
_ _ _____ _ _
W.C. Fields
