It is currently Sun Sep 23, 2018 6:20 pm
PostPosted: Fri Aug 26, 2005 4:23 am
Hi folks.
Right i have battlefield 2 and before i start i have to close down a load of progs using taskman. when i am through playing i then have to go in to start them all up again, they are AVG Zonealarm amongst others, if i dont i get connection errors.
Can i create a BAT file that will shut these down and another one to start them up again. if i can, How??
Thanks for the advice.
PostPosted: Fri Aug 26, 2005 5:35 am
taskkill will do it for ya: http://www.tech-recipes.com/windows_tips446.html
works similar to UNIX/Linux by killing the process ID.
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Fri Aug 26, 2005 5:57 am
thanks mate seems to work on everythin except zonealarm, any ideas on that one? also is there any way to start things back up using dos? with it being 32 bit etc.
